I know how to fix broken avi-files with VirtualDubMod but I'm looking for a way to do it from the commandline.
I'm not sure as to do this, do I need to create some sort of script, if so how?
I dont't need anything advanced, just to:
* Load the video
* Scan for errors
* Delete or mask bad frames
DivFix++ has a command line syntax. http://sourceforge.net/projects/divfixpp
Ok, so I've been playing around with DivFix++ and it seemes to fix it to some degree.
When I scan the fixed file in VirtualDubMod it seemes fine but I still have a problem.
The thing is that the file has a packed bitstream and I'm trying to unpack it with MPEG4 Modifier
and it couldn't open the original file, I got:
After the fix from DivXFix++, I now get:"This is not a valid MPEG-4 Video (Startcode not found at begining of frame)"
Acording to another forum:''Too many VOPs in a frame.''
The file created with DivXFix++ has 3 VOPs, could this be an error in DivXFix or can there be more than 2?"you will get this if there are more than 2 VOPs in a AVI frame. Usually there is only one, or 2 for each packed frame when packed bitstream was used."
When I disable that error-check in MPEG Modifier the file unpack and plays just fine so I got to wonder in which application the error lies.
Cutting Mp4 between I-frames, replacing some frames
By eymerich in forum EditingReplies: 4Last Post: 29th Jul 2009, 08:41 -
Cutting a M2V file or editing SINGLE FRAMES of it
By lorix in forum EditingReplies: 3Last Post: 13th Nov 2008, 03:05 -
Cutting 20 ms audio frames
By TrupsT in forum AudioReplies: 1Last Post: 31st Aug 2008, 23:21 -
How do I edit the frame rate of a selection of frames in VirtualDubMod?
By manilow in forum RestorationReplies: 4Last Post: 21st Dec 2007, 22:12 -
cutting a few frames from an avi
By tommid in forum Newbie / General discussionsReplies: 7Last Post: 17th Oct 2007, 18:52
