Hey everyone...
I was just curious if anyone knows of a transition for FCP that makes the footage flicker out (similar to the flicker text filter in Motion)? I've done lots of googling and found nothing so far...
anyone know if one exists?
:: ehmjay.
could you just not use the "glitch"filter
in the FxFactory Motion Pack
and set the amount of glitch to be smaller and less
hard of a shape, rather than squares to say dots?
or are you thinking more along the lines of a color or
intense bright "pop" flicker?
like this
but slower and more intense?"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
well I dont know if you've ever seen the flicker on filter for text in motion but something along those lines - only in reverse obviously - flickering out. kind of like a light that flickers out...
i will upload a clip from my film in which I have it with the text - i want to find some way to make an image do the same thing.:: ehmjay. -
Heres a clip of what im trying to achieve...
http://video.google.com/videoplay?docid=-98503064554800593&hl=en:: ehmjay. -
wow...it took me a bit to realize what you were trying to show.
it was very subtle, and since I don't use Motion
( my Dualie isn't up to spec to use it
It was the way the text flickered out, you want to do that
on your video.
the first thing that comes to mind is Masking the video at points along the timeline....
you could do 50%, 70% and then 100% masks at certain intervals,
say at every 50 seconds of the last 5 minutes to a complete black
fade out... 100%vid/50%msk/100%vid/70%msk/100%vid/100%msk
would achieve a similar result....use say 2 to 4second crossfades on
the mask so that it hits each point it will be a smooth and not jarring flicker.
For a sharp jarring flicker, say for a psycho feel, leave the crossfades
off and let each mask cut be hard...with the right music , you could
achieve a pretty cool piece..."Everyone has to learn, so that they can one day teach."
Urban Mac User -
okay that sounds like a good idea - it will just have to be addapted slightly as i dont want the whole film to flicker, merely at the end of this one shot - as if the shot is going out because the light goes out. something like that.
thanks.:: ehmjay. -
Nice effect. I'm submitting a comment because I'd like to be kept in the loop in case something can be created to do this.Originally Posted by ehmjay
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
FCP - "Title 3D" Missing - but it's not!
By ehmjay in forum MacReplies: 4Last Post: 23rd Jan 2008, 09:42 -
Flicker, scanlines and non "anti-aliased" image
By F u r u y á in forum Authoring (DVD)Replies: 2Last Post: 19th Jan 2008, 02:35 -
Burned DVD's "flicker"
By markannab in forum Authoring (DVD)Replies: 6Last Post: 27th Jun 2007, 03:45
