Can anyone tell me why this external HDD has 2 USB plugs?
	"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
	Not unless it was written in invisible ink. "Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
	There are 2 USB plugs so that if your computer (i.e. older laptops) can't summon enough power using one USB port then you can plug the second one in another USB port . The default plug is the two wires into one plug.
	Thanks for that. "Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
  External HDD Enclosure QuestionBy Timex in forum ComputerReplies: 4Last Post: 1st Aug 2011, 14:53
  blu ray hdd- external hddBy jayjay97 in forum Authoring (Blu-ray)Replies: 2Last Post: 25th Sep 2010, 01:35
  recover *.mts files from external HDD ..tried restoring hdd softwareBy ravistudios in forum RestorationReplies: 0Last Post: 18th Mar 2010, 13:24
  External HDD SuggestionBy sohaibrazzaq in forum ComputerReplies: 6Last Post: 12th Mar 2009, 10:02
  Traveling (US to Australia) with external HDD, power questionBy lumis in forum ComputerReplies: 3Last Post: 18th Sep 2007, 17:45
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
