I'm trying to mux a h.264 (video file), (ogg audio file), and srt (subtitle file) into a single mkv file in mkvmerge GUI v2.10, but an error message pops up.
Error Message: You're adding an AVC/h.264 elementary stream to the output file. mkvmerge cannot determine the number of frames per second for such files itself. Therefore you have to set this parameter yourself in the "format specific options" page. If you do not do this then mkvmerge will assume 25 fps.
I've tried it on 25 fps and the file turns out to be about 5 minutes too short, desyncing the video and audio. How would I be able to determine the fps of the h.264? (I have the original mkv that I demuxed to get the h.264 as well) And if it turns out that the h.264 has a variable fps, how would I mux my file together to get an mkv that works?
Yup, setting it to 23.976 worked perfectly. Thanks for the help guys.
Video Re-Muxing Problem: How to Re-Mux to M2TS?
By WellBeSerious12 in forum Video ConversionReplies: 5Last Post: 15th Sep 2011, 02:31 -
MKVToolnix muxing problem when adding or removing audio and subtitles
By firstliight in forum Video ConversionReplies: 1Last Post: 19th Nov 2010, 08:23 -
FairUse Wizard 2.9 muxing problem
By herbapou in forum DVD RippingReplies: 2Last Post: 17th Mar 2009, 11:21 -
mkv file audio muxing problem
By shun in forum EditingReplies: 2Last Post: 23rd Feb 2008, 08:15 -
converting framerate problem
By Shaorin in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jun 2007, 00:00
