    Aug 2006
    Greece
    I have a problem here! :P
    I have a movie which has hardsubs on it. So I'm using a filter in virtualdub to blur them, but after the re-encoding, the resulted video-file has its audio out of synch and the video, lags in some parts!
    what the heck I'm doing wrong? :P
    ps: when I load the movie, this warning appears:
    Feb 2004
    Australia
    Try using nandub to extract the audio as vbr .
    Jun 2007
    What I do in this situation is re-encode with the audio as CBR. Before you re-encode find the audio settings and make sure it encodes to CBR. Then it'll be fine.
    Aug 2006
    Greece
    what about the video lags?
    Aug 2006
    Greece
    I cant' fidn this option neither In Virtualdubmod either in Virtualdub, can you give me a hand here pls?:P
    Aug 2006
    Greece
    thx...for the no help...
  7. Mod Neophyte redwudz's Avatar
    USA
    I often use this method with VDM: https://forum.videohelp.com/topic280779.html
    Then I 'add' the WAV back in and re-encode it to CBR audio with LAME MP3 ACM.
