Hi,
I want to join a movie i got which is in two parts. If the files i add in virtual dub to join have exactly the same attributes(fps,bitrate,size etc.) will the result i get be in sync???
	SaM*T
	They should be if they were split properly in the first place. Just append the second to the first, save as 'Direct stream copy' and see. It only takes a few minutes. But some videos are split with no regard to joining them back together. Using MP3 VBR audio or not splitting on a key frame can cause problems when joining.
 If you were combining them to convert to a DVD, I wouldn't. Just encode the two parts separately to MPEG and let your authoring program do the 'joining'. That will improve the odds that there will be no sync problems.
  [VirtualDub] How to split avi to x parts with one operation?By ralf07 in forum Video ConversionReplies: 3Last Post: 5th Apr 2012, 18:01
  Is there a way to mute certain parts of a video with VirtualDub or VDubMod?By ilimitus in forum EditingReplies: 4Last Post: 4th Feb 2011, 02:18
  joining two avi parts that overlap?By nok32 in forum Newbie / General discussionsReplies: 6Last Post: 16th Nov 2008, 04:40
  Editing parts of the audio on VirtualDubBy ione in forum AudioReplies: 5Last Post: 19th Sep 2008, 05:57
  joining 2 parts of a DVD?By Itsmeshane in forum EditingReplies: 1Last Post: 23rd Oct 2007, 05:20
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
