Hi guys![]()
I've just bought a tv capture card and I was wondering if you could help me out with the setup?
My aim is to capture tv from my sky box at the highest possible quality. The capture card I'm using is the Pinnacle Dazzle Video Creator Platinum and I have this connected to my Sky Digi Box (standard definition) via an S-Video cable. The software I'm using is Pinnacle Studio Version 10.
If HD space/plugins/premium content isn't a problem. What are the best settings to use for capturing/editing at the highest possible quality? Also, do any other factors come in to it, regarding quality..say for instance..choice of S-Video cable, Sky Box Signal Quality, or maybe general picture settings like contrast, brightness, etc?
Any advice or tips would be very much appreciated, guys![]()
Kev
Results 1 to 1 of 1
Highest compatibility+quality suggestions
By BMemo in forum Newbie / General discussionsReplies: 11Last Post: 30th Jun 2011, 15:28 -
Highest quality backups
By freewave in forum Newbie / General discussionsReplies: 4Last Post: 13th Mar 2010, 19:32 -
What is the highest-quality capture card that I can get for my Xbox 360?
By FinalGypsy in forum Capturing and VCRReplies: 8Last Post: 13th Jan 2010, 11:12 -
Highest quality codec
By chizzle in forum Blu-ray RippingReplies: 6Last Post: 11th Feb 2009, 15:57 -
Compressing with the highest quality
By guitarscn in forum Newbie / General discussionsReplies: 6Last Post: 26th Apr 2008, 14:02
