I am new to ISO just wondering if there is a dvd that can be used to burn ISO on or larger CD's that I can purchase..
Said: Not enough disk space for my ISO file
Tks
How big is the iso? WHat is the content?
You could always extract the content from the cd-iso and burn on a dvd. -
Even using a ISO and burning in Mode 2, you're not going to get 1GB on a CD. About the best you could do is 830MB and that is not simple. You need to split that video over two CDs or use a DVD.
ImgBurn can burn it directly to a DVD. But you should know what format it is first to determine what you want to do with it. Also, what do you intend to play it back on? A set top DVD player, a Divx player, or just the computer?
If you need to extract it, you could use a program like ISOBuster or similar, then split or re-encode it as needed.
You can also play back ISO files with VLC Media Player or a few other players, if you just want to view it.
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 18:28 -
Avi2DVD help Iso too big
By martial4rtist in forum Newbie / General discussionsReplies: 12Last Post: 9th Apr 2011, 17:41 -
Tool recommend for *.avi ---> DVD(iso) and ripping a DVD to *.iso file?
By pxstein in forum Authoring (DVD)Replies: 4Last Post: 11th Jan 2011, 15:51 -
Why are my AVI2DVD dvd ISO files TOO BIG to burn onto DVD!?
By Xenogear900 in forum Authoring (DVD)Replies: 5Last Post: 1st Sep 2008, 21:20 -
question about how to use cue file to break big audio file into tracks
By jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 08:40
