  1. I've been using AutoGK for a while now to convert my DVDs to avi's & I want to try converting HD movies to xvids.
    I open the HD mpeg or .ts file in AutoGK, & set everything the same as I do for normal DVDs, except I set the width to 1920.
    The result looks really good, but I don't know if I'm doing the correct thing.
    Should I be converting to a different format, like mkv? Is it as easy as AutoGK?
    I would convert to h264 video instead of xvid. You can use MEGUI, not as simple as autogk though but just follow a tutorial.
  3. Thanks, I'll give it a try.
    But I guess your celeron 433 wont play any h264 hd...
  5. I guess I should update my stats
    Okay. I updated my stats, but I'm getting an Asus EN8600GT SILENT/HTDP/256M vc for the htpc on Wednesday.
