i coverted a divx Mpeg4 file to DVD using svcd2dvd and when it finished it plays fast like to 2 times faster .
the issue can also be seen in the S2D files ..
ive posted the log file ... thanks in advance ..
by the way i unintsalled all versions of svcd2dvd and downloaded the newest version 09/17/2007 and i'am testing new version, i have never had this problem before .
svcd2dvdlog-20070916232027.txt
	Ok but thats not the latest version you have 2.5.3000 it should be 2.5.3200 SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
	true , that log is from previous version after i got the bad results and i then i uninstalled eveyrthing and downloaded the new version and can report i still have the same issue ?
	Ok i have used the same files as you and not got the issue. In the Tools folder under SVCD2DVD there is a program to create samples... Can you make a sample (say 5MB) from one of the _S2D mpegs which plays too fast so i can take a look? Put the sample somewhere for me to grab or email it to me (see my profile). SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
	i used nero vision express and it worked , do u still want a sample for future ref ?
	Well if you have a sample showing x2 speed i would like to see it as when i did it at this end it was ok. Thanks. SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
  Video Uploaded on Youtube Plays Too FastBy selectivesloth in forum Video Streaming DownloadingReplies: 95Last Post: 10th Oct 2012, 10:10
  Converting Horse Feathers DVD to MP4 - audio plays too fastBy wkrick in forum DVD RippingReplies: 3Last Post: 7th Mar 2011, 19:04
  MPC and 60i Video Plays too FastBy ron spencer in forum Software PlayingReplies: 0Last Post: 16th Dec 2009, 20:33
  HD Tivo to DVD plays too fast on DVDBy davidrabin in forum DVD & Blu-ray RecordersReplies: 2Last Post: 31st Dec 2007, 13:46
  Streaming Media Plays Too FastBy TenaciousJP in forum Newbie / General discussionsReplies: 5Last Post: 18th May 2007, 00:30
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
