I want to edit the audio on several MPG clips before burning them to CD.
I was able to extract the audio as a WAV file, but dont know how to recombine with the video.
I thought I might bring them into VirtualDub and play around with them, but get the following error
"MPEG Import Filter: invalid packed at position 3: marker bit not set; possibly MPEG-2 stream". The files were originally created in TMPGEnc MPEG Editor. The files do play in WinDvd & WMP.
I also tried TMPGEnc MPEG Editor as a possible way to combine the audio and video, but it will only let me specify an MPG file as the audio source (how would I convert my WAV files to MPG?)
So the question is what is the best way to edit the audio in my clips.
Yup, that's true. Muxed Mpeg files are only happy with a variation of WAV called LPCM. You can convert it with the SOX command line utility. The syntax would be:
sox your_audio_file.wav -t raw -sxwr48000 Output_File.lpcm
You could also convert your audio with ffmpeggui to MP2 or AC3 , which will also work with MPEG2 muxing.
Also, virtualdubMOD and VirtualDubMPG2 will open the Mpeg2 file, NOT virtualdub -
Virtualdub 1.4.13 will open mpeg2 .
Multiplexing back together :
And old method was to use bbmpeg in multiplexing stage only ... a small avi is need to activate functions , then you can access the encoders settings where multiplexing functions hide .
Audio would need to be converted to mp2 / ac3 for this , and exact length .
Baldrick at one stage showed how to multiplex a portion of such clips .
ImagoMPEG-Muxer
Mplex found in dvdauthgui package , and others
mplex.exe -f 8 -o "C:\myfile\youclipsname.mpg" "C:\myfile\youclipsname.mv2" "C:\myfile\youclipsname.mpa"
Mpa/ac3/mp2/lpcm
Tmpgenc > http://www.afterdawn.com/guides/archive/advanced_tmpgenc_guide_page_5.cfm
Option one is simple multiplexing , make sure "type" is set correctly .
Third option > multiplex ... same with "type" .
You may have a non-registered version which might prevent this action after 30 days ... then mpeg2 work stops unless you buy a license .
Mpeg streamclip
Window > preferences > fix streams with data breaks .
And of course graphedit ... but explaining it is another thing .
https://forum.videohelp.com/topic335574.html?highlight=graphedit ... last post
Audio conversion = besweet .
Using Premiere CS4 to edit Ripped Clip
By jbandy1 in forum Blu-ray RippingReplies: 2Last Post: 15th Nov 2010, 10:34 -
Edit clip from two camera
By Cazz in forum EditingReplies: 9Last Post: 1st Jul 2010, 14:41 -
need help on how to crop/edit with mpg stream clip
By mike300 in forum Software PlayingReplies: 10Last Post: 12th Jun 2010, 18:48 -
Mute and edit clip without re-encoding
By exon in forum Newbie / General discussionsReplies: 2Last Post: 31st May 2010, 09:30 -
Remove audio from .mpg clip?
By Silvy in forum AudioReplies: 4Last Post: 24th Jun 2007, 17:41
