Hi yall
is there some samples out with diffrent bitrates and resolution to test you vcd, svcd or dvd player??
i mean
some samples of movies of 1 mins and they have all diffrent bitrates and resolutions so i can burn the samples and c what my dvd player can handle
so i know at the end what my dvd player can play, what it's maxmum and minimum bitrates, resolution are.
sort of test cd
example (all 1 min):
VCD
Sample01 MPEG-1 352x240 25fps CBR 700kbps, Layer-2 44100Hz 128kbps
Sample02 MPEG-1 352x240 25fps CBR 800kbps, Layer-2 44100Hz 128kbps
Sample03 MPEG-1 352x240 25fps CBR 900kbps, Layer-2 44100Hz 128kbps
Sample04 MPEG-1 352x240 25fps CBR 1000kbps, Layer-2 44100Hz 128kbps
ETC (till 4000kbits or something)
Sample05 MPEG-1 352x288 25fps CBR 700kbps, Layer-2 44100Hz 128kbps
Sample06 MPEG-1 352x288 25fps CBR 800kbps, Layer-2 44100Hz 128kbps
SVCD
Sample07 MPEG-2 480x480 25fps CBR 700kbps, Layer-2 44100Hz 128kbps
Sample08 MPEG-2 480x480 25fps CBR 800kbps, Layer-2 44100Hz 128kbps
Sample09 MPEG-2 480x480 25fps CBR 900kbps, Layer-2 44100Hz 128kbps
Sample10 MPEG-2 480x480 25fps CBR 1000kbps, Layer-2 44100Hz 128kbps
ETC (till 5000kbits or something)
Sample10 MPEG-2 480x576 25fps CBR 700kbps, Layer-2 44100Hz 128kbps
Sample11 MPEG-2 480x576 25fps CBR 800kbps, Layer-2 44100Hz 128kbps
X(S)VCD
Sample12 MPEG-2 720x480 25fps CBR 700kbps, Layer-2 44100Hz 128kbps
Sample13 MPEG-2 720x480 25fps CBR 800kbps, Layer-2 44100Hz 128kbps
Sample14 MPEG-2 720x480 25fps CBR 900kbps, Layer-2 44100Hz 128kbps
Sample15 MPEG-2 720x480 25fps CBR 1000kbps, Layer-2 44100Hz 128kbps
Sample16 MPEG-2 720x576 25fps CBR 700kbps, Layer-2 44100Hz 128kbps
Sample17 MPEG-2 720x576 25fps CBR 800kbps, Layer-2 44100Hz 128kbps
Sample18 MPEG-2 720x576 25fps CBR 900kbps, Layer-2 44100Hz 128kbps
Sample19 MPEG-2 720x576 25fps CBR 1000kbps, Layer-2 44100Hz 128kbps
and if it's possible CVD CDVD and miniDVD samples with diffrent bitrates and resolutions
i don't know much about CVD CDVD and miniDVD
is there something out like this?? but not with still picture a sort part of a movie or something (1 min will do it)
so i know what the min and max bitrates and resolution of my ,vcd, svcd or dvd player is
thanks in advance
I dont think you will find samples for all that...but you could easily make own samples, just get a good source video file and use tmpgenc and start encoding and burn with vcdeasy in vcd 2.0 mode.
A 1 minute sample isn't enough. You really can be sure your player can handle 700 kbs only after watching a full test disc through. For example my Philips DVD 622 plays nearly everything I trow in, but every VBR VCD / most SCVDs (trying to get the max playtime) will hang once in a while. The XVCD may play OK for 60 minutes and only then the problems arise
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
VCD o SVCD with extra data (installers)
By pmaril in forum Authoring (VCD/SVCD)Replies: 12Last Post: 17th May 2008, 18:17 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 11:56 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 21:25 -
How to copy-protect a VCD/SVCD v2.0
By Sine29 in forum User guidesReplies: 23Last Post: 20th Jul 2007, 11:27
