I've always loved Virtual VCR, and want to use it on my new system.
I have a satellite receiver, and its s-video and audio outputs enter my sytem via my ATI TV Wonder "purple input thingy" that sits on my desk.
I get sound and video when using the ATI software, as well as the Snapstream Beyond TV, but I'm having probs with Virtual VCR.
I get video, but no audio.
Any ideas? Should I split the audio leaving the satellite receiver to enter through both the ATI card and the line-in audio jack? Is there someway to select the ATI audio in Virtual VCR?
Thanks in advance.
I'd rather die of thirst, than drink from the cup of mediocrity.
I use virtual vcr all the time to capture vhs tapes (but not with my sat decoder)
I'd suggest you to use win dvr3 for that ...that's just my opinion
Anyway for your audio problem there is a good chance that you didn't choose the right input ("line in" for instance)
or you probably have it set on right input but the level is very low hence the "no audio result"
1st check the windows audio volume/input panel:
start>run: and copy
aste & enter this:
%SystemRoot%\system32\sndrec32.exe
2nd: check the audio settings in virtual vcr:
settings>audio*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE
Little setting problems with VirtualVCR
By Greycat in forum Capturing and VCRReplies: 10Last Post: 28th Jul 2015, 19:07 -
VirtualVCR cap fails in virtualdub...
By Asesinato in forum Capturing and VCRReplies: 36Last Post: 12th Apr 2012, 12:43 -
need help with ati TV wonder 650 USB - no sound with virtualvcr
By deffy in forum Capturing and VCRReplies: 15Last Post: 6th Aug 2010, 04:16 -
VirtualVCR Tweaker
By Torrential in forum Capturing and VCRReplies: 1Last Post: 21st Apr 2010, 05:24 -
VirtualVCR help
By LittleJimmy in forum Capturing and VCRReplies: 3Last Post: 12th Jan 2009, 00:34
