Why does a audio file that sounds bad on PS2 sounds perfect on computer? How can I determine what is needed for that file to sound close to perfect in PS2? Is there a program that can recreate the PS2 problem on computer and possibly give an idea to correct it? Container is mpeg-ps,codec is ac-3 though i used mp2 and it sounded the same on PS2 but perfect on computer.
The problem in in your PS2. You need to look into the audio there. The fact thta it sounds fine on teh computer means it isn't the file but the playback software/hardware that has a problem.
Start with "how" you are transferring such content to the ps2 .
Media related ... either media is poor quality , or the unit is having an issue playing from that particular brand .
Then it might be , ps2 (laser issues) , cables , receiving unit . -
semi-solved! after more research on ps2 versions, itested the dvd in a ps2 slim and the dvd played perfect. so my older v. does'nt support it. Something to do with the firmware, which I can't find anywhere. thanks.
I have both ps2 units and don't have dvd playback issues with either ... 30002 + 75002
MKV file audio out of sync on my computer, inferior computer plays perfect
By dave in or in forum Newbie / General discussionsReplies: 7Last Post: 5th Aug 2011, 21:56 -
Ripping Audio from PS2 Game Bully?
By coondog1234 in forum AudioReplies: 2Last Post: 10th Mar 2010, 09:47 -
VOB2MPG and network paths
By kfealz in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 5th Jan 2010, 19:21 -
Using Super - can paths be changed?
By Will_Annand in forum Video ConversionReplies: 3Last Post: 4th Jun 2008, 13:24 -
Moving Paths/Keying Help
By Trunkz Jr in forum EditingReplies: 6Last Post: 10th Apr 2008, 18:01
