Why does this binary have the Excel graphic attached to it? The fiel name is mpeg2enc.intel - should I rename this file and use a different file extension suffix?
Thanks!
Mac OS X tries to match files to applications in a number of ways, and sometimes it makes a wrong assumption. The icon and suffix (even the filename!) are not important, the installer should take the binary file just fine, as long as the content of the file is right.
You could try a different copy with the right icon, if that would make you feel better, tho'.
Trouble Installing to OS X 10.5 (mencoder, mplayer, mpeg2enc.intel)
By gabroll in forum ffmpegX general discussionReplies: 21Last Post: 10th Nov 2010, 10:48 -
mpeg2enc install, intel only?
By cjk in forum ffmpegX general discussionReplies: 1Last Post: 4th Jul 2009, 15:04 -
Unable to download mpeg2enc for Mac intel
By its1235 in forum ffmpegX general discussionReplies: 14Last Post: 22nd Mar 2009, 12:00 -
Intel Q6600 Kentsfield or Intel E8400 Wolfdale??? Help me decide which one
By budz in forum ComputerReplies: 33Last Post: 12th Mar 2009, 00:19 -
mpeg2enc on non-intel machine
By Zownd in forum ffmpegX general discussionReplies: 2Last Post: 3rd Jan 2008, 15:15
