Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
    Sep 2007
    So, I have a Hitachi P42H401 Plasma HDTV. When I use an HDMI cable to connect my cable box to the TV, 4:3 aspect ratio is no longer a valid selection. Only 4:3 stretched is available along with all the 16:9 choices.
    The problem with this is that ALL broadcast HD channels (in Austin anyway)...ESPN, ABC, CBS, NBC, etc...all display correctly as 16:9 when using the 4:3 aspect. When using a 16:9 aspect setting, the screen is stretched (i.e. football players appear short and stocky) and the far edges are off the screen.
    Is there a way around this? HD looks like crap using any cables other than HDMI.
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Austin? Time Warner? Sci Atlanta HD box? Which model?
    Somewhere in your cable box menus you will find a menu selection for 4:3 with sidebars vs. 4:3 stretch.
    Sep 2007
    Yes to all the questions. It's model 8300HD. Seems that I needed to add all the various resolutions that my TV can handle. You turn the DVR off, hit GUIDE & INFO and select the various resolutions. That fixed it. It would be nice if that info was actually in the DVR's book instead of having to search on the internet for the info. It works perfect now!
