I would like to take a short video clip - a few seconds - and convert it to a series of jpg files.
Maybe even something I can use from the command prompt.
Does anyone know of a free (preferably) program that can do this?
There is more to life than meets the microscope.
virtualdub or virtualdubmpeg2 or virtualdubmod, file->save image sequence.
I guess you can use mencoder or ffmpeg from the command prompt to output jpgs also but I'm not sure how.
Sync/align one short clip into one big clip
By diamondback in forum AudioReplies: 1Last Post: 2nd Nov 2011, 10:31 -
Converting a 480x720 2:3 short to a 1280x720 16:9 HD short.
By Cyrax9 in forum MacReplies: 2Last Post: 14th Feb 2011, 17:40 -
How to make a short animated movie/video clip? Example included.
By UmmAddan in forum Newbie / General discussionsReplies: 1Last Post: 3rd Feb 2009, 10:36 -
Cutting a short clip from a DVD
By Nutmeg7 in forum MacReplies: 1Last Post: 13th Nov 2007, 23:58 -
How to make a short clip?
By kenzo69 in forum ffmpegX general discussionReplies: 2Last Post: 18th May 2007, 20:15
