Hello,
I use DVD fab 3.1.8.0 platinum
I ripped a movie that lasts for 1 hour and 33 minutes.
I used all the defualt settings except I set "fixed size to 700mb" and it automatically selects a bitrate.
Here are the settings I used.
http://vlturbo.ath.cx/settings4.PNG
I had also selected Pass 2 Encoding for higher quality
I ended up with a 700mb file, and the quality was appaling you could see artefacts everywhere.
Any help on how to get a good quality 700mb file?
Thanks,
kidcash.
Results 1 to 17 of 17
I'd do it in seperate processes. I'd rip it first intact with no compression. Then I'd use something like virtualdubmod or virtualdubmpeg2 with divx or xvid and use one of the presets. I personally don't like all in one solutions - unless I'm being lazy!
It's better to use dedicated programs for each solution.
Besides its not the ripping that was at fault it was the compression method use. (terminology is important in the tech world).Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Why are you forcing the program to transcode down to 700mb? How big are the files you are ripping (not just how long they play)? You may be asking this program to increase compression an awful lot, if you are going from a full multi gb set of dvd .vob files - down to 700mb? This could easily cause pretty terrible video results from most any program.Originally Posted by kidcash
rich86 is correct in that the compression you're asking for may be too extreme. Since you are most likely putting this on a cdr why not increase the birate and use two discs instead of one? CD'R's are dirt cheap these days and you'd get better quality even if you have to swap discs part way through the movie.
Kidcash wrote" I think there is some setting that I have set wrong in dvdfab, As other people say its a great program.
DVDFab is a great proggy IMO!...I just don't use it for DVD to AVI conversion.. AutoGK, FairUseWizard, Super....to name a few I use....and recently avi.NET as well....." Who needs Google, my wife knows everything" -
the whole movie is 3.7gb, its a DVD Movie.
700mb is the Usual size of most DVD Rips, and I have seen better quality dvd rips at 700mb.
I am trying Fairuse wizard as we speak. AutoGK did not work for me -
DVD writers are under $35 shipped.
Why not install a DVD burner?????
You can actually buy DVD-R or +R media for nearly the same as CD-R media.
That 3.7 GB dvd could've been ripped to an .iso file with DVD Decrypter, and burned - without any other software.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
Hi
If you use the H264 encoding option in DvdFab you will get very acceptable results even to a 700Mb file.
The resultant file will have the .mp4 file extension. Just change this to .avi and away you go.
I have just converted a 2hr 40min DVD to a 700Mb file using the H264 codec option and the result is excellent. Much better than Xvid in my opinion. -
Your right, but that is not what I intend to do, otherwise I would have posted in a different section on the forum.Originally Posted by classfour
mesaboogieman is right. Speaking in general, H264 can do within 700 MB or less
the same as DivX/XviD must do within 1.3 GB or more.
I think I have fixed it, Instead of chosing generic.avi.audiocopy I chose generic.avi.mp3 and now the bitrate is 911 for the Video instead of about 600 which it was last time.
I have encoded one Video in H.264 and it looks good, I am going to try now with Xvid. My last video was encoded at 720 x 400 but I had 2 Black bars on my video, and I dont want the bits getting wasted for those 2 black bars, meaning that the actual image has less quality.
Is there any way to get rid of these 2 black bars? maybe set a different resolution? -
The black bars are still part of the Video file, and quite a lot of it. Proper DVDrips have no black bars.
I have read that it removes the black bars, I think using Avisynth.
The problem is that it crashes.
http://forum.doom9.org/archive/index.php/t-102012.html
Have tried the fixes explained there but no luck.
Problem with DVDFab and Blu-Ray rips looking washed out.
By billw6560 in forum Blu-ray RippingReplies: 18Last Post: 5th Apr 2012, 17:39 -
YouTube Rips - Audio Quality
By kingoftomorrow in forum Video Streaming DownloadingReplies: 1Last Post: 5th Mar 2012, 16:48 -
DVD Decrypter rips where DVDFab can't
By audax in forum DVD RippingReplies: 2Last Post: 3rd Jan 2010, 19:27 -
Poor Quality Out of TV Show Rips
By ajedale in forum Newbie / General discussionsReplies: 8Last Post: 21st Jun 2009, 20:11 -
DVDfab rips out many video_ts, how do i join them together
By Cococokie in forum DVD RippingReplies: 1Last Post: 28th Dec 2007, 05:40
