    Nov 2006
    Hello there
    I replaced my DVD drive unit a few months ago. I bought a LG GSA-H42N and it has worked fine so far.
    Now, all of a sudden, the drive is very slow. Both reading/decrypting and burning are done at a maximum of 1.2x .
    My IDE settings are as follows:
    Primary IDE Channel
    Device 0
    Transfer Mode: DMA if available
    Current Transfer mode: Ultra DMA Mode 5
    Device 1
    Current Transfer mode: n/a
    Secondary IDE Channel
    Device 0
    Current Transfer mode: PIO Mode
    Device 1
    Current Transfer mode: Ultra DMA Mode 2
    Does this depend on the PIO Mode on Secondary IDE Channel. If so, how can I change it?
    Any help will be GREATLY appreciated.
    Thanks in advance
    Cosmo
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Delete the channel and reboot the computer. No harm will come of it.
  3. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    A Sticky should be made since this question is quite often asked. If any moderator is online would you consider it?
