My DVD player (JVC-THS3) is old and can only play MPEG4 files - according to the manual.
What is the best way of converting AVI files to MPEG4 files based on the following info from the DVD players manual?:
Notes on MPEG4 files:
The system can play back MPEG4 files based on the following conditions:
File format: ASF
Visual Profile: MPEG4 SP (Single Profile)
Audio Codec: G.726
Max Pic Size: 352 x 288 (CIF)
Max Bit Rate: 384 kbps
Info form the type of files I want to convert:
File : 699 MB (699 MB), duration: 1:41:06, type: AVI, 1 audio stream(s), quality: 45 %
Video : 607 MB, 839 Kbps, 23.976 fps, 592*256 (2.21:1), XVID = XVID Mpeg-4
Audio : 92 MB, 128 Kbps, 48000 Hz, 2 channels, 0x55 = MPEG Layer-3
	Try Windows Media Encoder.
 But you would get better quality by converting to dvd-video with for example convertxtodvd.
	Thanks for your reply Baldrick....
 I don't know what I was thinking!! I will convert to dvd-video instead... it makes more sense.
  Convert Webcam Video for TV - uncompressed avi > asf > mov - best solution?By nakedgun in forum Video ConversionReplies: 0Last Post: 17th Nov 2011, 06:41
  Convert HDTV ts files to DVD mpeg or AviBy kenmo in forum Video ConversionReplies: 5Last Post: 6th Nov 2011, 10:17
  any ways to convert from avi to asf very quickly?By George2 in forum Newbie / General discussionsReplies: 34Last Post: 20th Apr 2009, 04:02
  Conversion from asf files to avi or mpegBy Jescal in forum Video ConversionReplies: 1Last Post: 23rd Jan 2008, 17:37
  Convert .avi to play on a DVD playerBy Aaron1978 in forum Newbie / General discussionsReplies: 5Last Post: 22nd Sep 2007, 14:06
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
