I've noticed in Pgcedit and Vobblanker that previewing part of the video looks a tad faster than normal. This doesnt matter to me in those programs, but now it's happening in Mpeg2schnitt which is preventing me from making accurate edit points (the audio still plays normally in the edit window - they're demuxed streams). What might be going wrong and how can I remedy?
Probably some problem with your default mpeg2/dvd decoder. You can try install another one or try switch the default decoder with windows decoder checkup utility, http://www.microsoft.com/downloads/details.aspx?FamilyID=DE1491AC-0AB6-4990-943D-627E6...displaylang=en
Thanks! I downloaded it, and it shows 6 decoders. Can you tell if there's a conflict going on, or if it all seems fine? Should I uninstall any?
Only one decoder, which is selected, is compatible with both XP and Windows Media 10. The other 5 are mostly incompatible.
SELECTED: CyberLink Video/SP Decoder (CLSVD.ax)(MP10 and MCE Compatible)
Nero DVD Decoder (NeVideo.ax) (MCE Compatible)
Nero Video Decoder (NeVideo.ax)
ffdshow Video Decoder (ffdshow.ax)
ffdshow raw video filter (ffdshow.ax)
GPL MPEG-1/2 Decoder (GplMpgDec2.ax)
I tried selecting the other decoders but no change with the programs. Interestingly, Mpeg2schnitt shows the video-time for a test clip as 1min51sec, when it should be 2min18sec. -
I noticed that Windows Media player plays demuxed mpeg2 (no audio) too fast. When I loaded demuxed video/audio into TDA, it recognized the runtime correctly but didn't mux correctly. So in general, it seems to be a problem when I try to play video (no audio) only. I guess noone here has experienced this?
I figured the m2v (and mpeg2 in video-only ware) that were playing too fast have different pics/second than the video that plays normally. Gspot says about 24 pics/s. Normal playing video was about 30 pics/sec. They both are about 30 frames per second.
So it seems the computer is playing the 24 pics at about 30 pics/sec. But how to fix it?
Unable to play asset in preview window
By gstewart in forum Newbie / General discussionsReplies: 2Last Post: 3rd May 2010, 20:04 -
Vegas Preview Window is choppy--please help!
By duderdude2 in forum EditingReplies: 8Last Post: 24th Mar 2010, 15:29 -
No Video in Preview Window.
By therearenorules in forum Capturing and VCRReplies: 0Last Post: 18th Jan 2009, 15:21 -
Image Snapshot in Vegas Pro 8 Preview window
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 29th Dec 2008, 16:48
