Please Help,
Every time I try to capture video and make a VCD it turns out very blocky.... Almost looks like things are made out of legos its that bad.
The first 5 seconds of the VCD are perfect then it turns into a blocky lego fest. Please Give Any Advice.
Im using the following:
AMD Duron 800
Asus SiS 630/730 video
ATI Wonder VE capture card
112 MB Ram
30 gig harddrive
ATI Mulitmedia Center 7.1 "Digital VCR"
DirectX 8.0 with directx 8.0 Video Capture Patch MS
Windows 98
This is my fourth try to post a reply. The first three didn't make it.
If the original mpg file plays OK on Windows Media Player and the VCD player displays blockyness the problem is probably in your burner hardware. The VCD standard explicitly EXCLUDES error correcting blocks to maximize the amount of video information contained on the VCD disk. So if your burner makes mistakes they will not be corrected on playback of a VCD.
Try burning the original mpg file on a DATA CD and try to play the file directly from the DATA CD using Windows Media Player. If the blockyness disappears or is much improved it is becaused the error correcting blocks on the DATA CD tracks are correcting the errors that were made during burning.
I and two of my friends had this same problem and cured it by buying new burners.
Hope this helps!!
Blocky artifacts on authored video---what gives????
By unclescoob in forum Newbie / General discussionsReplies: 5Last Post: 23rd Feb 2011, 17:24 -
Blocky artifacts in video, part 2
By The111 in forum Newbie / General discussionsReplies: 11Last Post: 17th Dec 2010, 13:10 -
Ati All In Wonder HD and PS3 screenshots and capture HD video.. help needed
By C.P in forum Capturing and VCRReplies: 6Last Post: 30th Mar 2010, 18:46 -
Video Capture with ATI TV Wonder Elite on Vista Ultimate
By Petes457 in forum Capturing and VCRReplies: 2Last Post: 30th May 2008, 10:55 -
Any Video Capture Software for ATI Theater 550Pro?
By quantass in forum Capturing and VCRReplies: 1Last Post: 8th Sep 2007, 19:26
