Hi, i'm a newbie to this so please excuse my ignorance
My dvd recorder screwed up a tv recording on a dvd-rw disc
so i have been trying to use dvdlab pro2 to recover the recordings
i get as far as the verification stage but then recieve an alarm sound and
an error message:Pre verification fails. Process abort ! - 1998
the report is as follows:
*** DVD Aa2 Pro Verification Log ***
9 - 13 - 2007 -- 12:56:43
* VMG Verification *
Number of VTS - 1
Number of Menus: 1
Menu 01 - Type - Dummy
Number of imported VTS: 0
* VTS Verification *
<<< VTS Number 1 >>>
Number of Titles: 1
Actual title count does not match with assigned title count
Number of Menus: 4
Menu 02 - Type - Still
nMenu cell count - 1
Menu Image File C:\Documents and Settings\a\disc 64\54650752_tmp1.bmp
Picture size - 720 x 576
Menu Audio File - None
Menu Sub-Picture File C:\Documents and Settings\a\disc 64\54650752_tmpsub1.bmp
Menu 03 - Type - Still
Menu Image File C:\Documents and Settings\a\disc 64\55035328_tmp1.bmp
Menu Sub-Picture File C:\Documents and Settings\a\disc 64\55035328_tmpsub1.bmp
Menu 04 - Type - Still
Menu Image File C:\Documents and Settings\a\disc 64\79223256_tmp1.bmp
Menu Sub-Picture File C:\Documents and Settings\a\disc 64\79223256_tmpsub1.bmp
* Status Messages *
if anyone has any ideas i would be most grateful
many thanks-luv
Postie1392
other messages i recieve are shown as screenshots:
image4.psp
Results 1 to 11 of 11
First, a couple of tips
1. Post images in a more user friendly format, such as jpeg. Not everyone has Paint Shop Pro.
2. Post as much information as possible. Better to put too much detail than not enough.
3. Post only in one forum. If you aren't sure where, post here and a mod will move it if necessary.
In the spirit of point 2 therefore;
How did you rip the video from the disc ?
Does the video play on your PC after ripping ?
Did you demux the video before importing into DLP ?
Can you open the video in g-spot and post a screenshot of the details.Read my blog here.
thanks for the tip, sorry about the image file, that was an oversight-i thought i had sent it as jpg.
I simply used copy & Paste to rip the video to my hard drive, and the video
plays fine on my pc.
i shall try demux and also send you a screenshot of details from g-spot asap.
thanks very much for your help
postie1392 -
Your menus are fine it looks like you have too many titles in Connection window and they are not in Asset bin or connection fo the file in Asset bin is not there (cannot find file location on your HD).
I suspect that your main problem is because you are using >VRO files, not VOBs or elementary streams. Your second problem will be that the video is half D1, so make sure your project settings allow for it or you will still get compile problems.
But first you need to get the mpeg video/audio off the disc in a usable form. G-spot thinks this is a VOB, so perhaps .VRO has the same basic format as a VOB container. If so, try changing the extension from .VRO to .VOB, then opening it in DLP. If you still don't get prompted to demux, then check to see if you have turned this option off (Project -> Properties -> Options -> VOB set to Always Ask). If it was turned off, set it back on a try again.
If the option is already on, then try using VOB2MPG to extract the mpg programme stream, then load this into DLP.Read my blog here.
Thanks for the tips, i will try them asap, and inform you of the outcome (probably over the weekend)
i have one more question:
the video is made up of 4 episodes of tv programmes that were recorded
on different days, and yet they appear as one video on the disc.
is there any way of splitting the video back into the four sepperate movies
in dvdlab pro2, or is there other software that you may be able to recomend that would do the job?
many thanks
postie1392
VOB2MPG should see them as 4 titles and give you four files accordingly.
DLP has a trim function, so if VOB2MPG does give you a single file, you could load it four times into DLP, and trim each version down to one episode.
Or you could use the demo version of VideoRedo to trim it (best option is VOB2MPG doesn't work)Read my blog here.
Hi again.
i have tried changeing the file extension to .VOB
the file still plays fine and will open in DLP.
However, when the VOB file window pops up on opening the video file
all the buttons are closed and it does not give me the option to demux.
see screenshot
And now i have got a shiny new verification report:
9 - 24 - 2007 -- 22:6:38
Number of VTS - 1
Number of Menus: 1
Number of Titles: 1
Title 01 - Type - VOB
Segment 1, Video File D:\Video\disc64\DVD_RTAV\VR_MOVIE.VOB
Video type does not match
Frame size: 352 X 576
Frame rate: 3 [1--23.976, 2--24, 4--29.97, 3--25, 5--30]
Aspect Ratio: 43 [43--4:3, 169--16:9]
Chroma: 1 [1--4:2:0, 2--4:2:2, 3--4:4:4]
Audio Stream Count: 1
Subtitle Stream Count: 0
Audio type: AC3_Mot, Channel: 1, Sampling: 48000, Bitrate: 192000
Number of Menus: 3
Menu Image File C:\Documents and Settings\a\disc 64\54650688_tmp1.bmp
Menu Sub-Picture File C:\Documents and Settings\a\disc 64\54650688_tmpsub1.bmp
Menu Image File C:\Documents and Settings\a\disc 64\390134296_tmp1.bmp
Menu Sub-Picture File C:\Documents and Settings\a\disc 64\390134296_tmpsub1.bmp
* Status Messages *
I have, as yet, been unable to load VOB2MPG onto my system,
i think i need to instal .NET Framework Version 2.0?
so will try that next.
thanks for all your help, i have at last managed to demux the
VRO file into something i can work with. if it helps anyone else, here is
how i done it:
1: change the file extension from VRO to VOB in windows explorer
2: open the file in DLP, you should then be asked what you want to do with the file. change the setting in "what to do next time you load such a file" to automaticaly demux.
3: close the project, and reopen the file in DLP. it should then automatical start to demux the file.
4: when it has finished you should now have files that DLP can work with.
once again, thanks for your help. there is no way i would have been able to work out how to do it without it
Why is DVD-Lab Pro2 upgrade not available
By lgh529 in forum Authoring (DVD)Replies: 3Last Post: 30th Jul 2011, 15:03 -
No audio and subtitles in DVD-lab PRO2
By 6ZIX in forum Authoring (DVD)Replies: 13Last Post: 11th Feb 2009, 08:14 -
DVD Lab PRO2 question
By mvp in forum Authoring (DVD)Replies: 9Last Post: 20th Apr 2008, 20:28 -
Exported AVI from Premiere pro2 have problem!!!
By yunakokimama in forum Newbie / General discussionsReplies: 0Last Post: 17th Apr 2008, 20:29 -
dvd-lab pro2
By postie1392 in forum DVD RippingReplies: 1Last Post: 15th Sep 2007, 05:32
