i'll notify all the contributors @ day of release wich is like in 2 mnths :O
Results 1,621 to 1,650 of 1969
So what did youtube exaclty block? did they Block hour methods or did they block every possbile way of uploading HQ?
man that sucks that ur not coming back to youtube frifox, now what ru gonna do?Originally Posted by frifox
They blocked the way of uploading HQ FLV files.Originally Posted by venomite
All FLV files get reencoded to horrible quality. [/b] -
i tried uploading an FLV file with FIG, and guess what? it said Failed file to small
well I worried this would happen, that YT would simply encode all uploads, but at least the ones I've uploaded remain flv HQ. The thing now is to hope they don't re-encode our already uploaded flv's. One thing to do is make sure you don't get copyright infringement warnings. After 3 copyright claims they closed my old account. (just clips from NBC tv)
And padding to 10:59 for &fmt=18 playback still boosts the bit rate playback? -
After many tests I reached a conclusion that our put videos are being altered in the 2-pass mode (&fmt=18)(X264) and if we will add empty frames it is obvious that the quality will be left great this way it is looking out in theory.Originally Posted by mikejf
http://youtube.com/watch?v=YlUq1NThtxc&fmt=18
OR
http://www.youtube.com/watch?v=NwidrwyX4lg&fmt=18
video specifications which is seen on youtube
HQ(&fmt=18):
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 21.1 MiB
Duration : 10mn 0s
Overall bit rate : 294 Kbps
Encoded date : UTC 2008-07-27 17:04:43
Tagged date : UTC 2008-07-27 17:04:43
Video
Format : AVC
Format profile : Baseline@L2.1
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Codec ID : avc1
Duration : 9mn 59s
Bit rate mode : Variable
Bit rate : 272 Kbps
Maximum bit rate : 5121 Kbps!!!!!!!!!!!!!! YES :P
Width : 480 pixels
Height : 360 pixels
Display aspect ratio : 4/3
Frame rate mode : Constant
Frame rate : 25.000 fps
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.063
Stream size : 19.4 MiB (92%)
Title : (C) 2007 Google Inc. v06.24.2007.
Tagged date : UTC 2008-07-27 17:04:44
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 10mn 0s
Bit rate : 17.7 Kbps
Maximum bit rate : 248 Kbps!!!!!!!!!!!
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 44.1 KHz
Resolution : 16 bits
Stream size : 1.27 MiB (6%)
Tagged date : UTC 2008-07-27 17:04:44 -
.Originally Posted by falcionxx
thanks, those trailers look very good- what format/specs did you upload them in? -
he is not making any difference important if only to add empty frames at the film's ending because then the quality is just averaging and the quality of the film is staying automatically raised but even without adding empty cages On2 VP6 is also a good codecOriginally Posted by mikejf
I upload:
X264
480x360
23,967 FPS
BITRATE FULL VBR (Auto Disortion Quantization)(2-pass) -
I agree with falcion. From my experience, adding black frames to the end of a normally uploaded file will have no effect. I tested two 1:24 clips, one unpadded, one padded to 11:00, both encoded in x264-vfw single pass lossless. Nothing different.
MeGUI 0.3.0.1020Originally Posted by TheGoldStar
Sorenson Squeeze 5
Nero Recode 3 -
from my trying, adding black frames stills can improve quality, both in normal quality mode and in &fmt=18 mode.
especially in normal mode, less mosaic than no padding one.
but I have a question, can we use the youtube trick on other website?
I try this on dailymotion, but get re-encoded. -
Isn't dailymotion high def anyways? I don't think you need to add any padding/tricks..
As many of us have noticed by now, YouTube has been busy tweaking it's compression techniques lately as they roll out "standard" and "high quality" versions of video uploads. As most who follow this thread know, YouTube now recommends uploading files in MP4 format using the larger VGA video size. These "improvements" have made lots of trouble for content producers. Proven tools and tutorials that were "standard operating procedure" for quality results have been rendered obsolete. There is evidence of this in blog posts all over the web.
Over the last few days, I have been trying to find a suitable (but simple) workaround. And I think I've discovered one. Be warned -- this fix may be temporary if YouTube continues to "enhance" its compression techniques. But as of 04-AUG-2008, the process works just fine for me -- and it doesn't require money or much effort.
My commercial software has become virtually useless at the final stage of production just before upload. But I found a freeware tool called WinFF -- see http://www.winff.org -- that does the trick. And it's fairly straightforward to use.
As YouTube now suggests, you want to convert your high quality video to MP4. And this is where WinFF shines. First, open your source video in WinFF and select 'Options' to adjust the conversion settings as follows:
Convert to: MP4 > H.264 in MP4(4:3)
Video Bitrate: 2000
Frame Rate: 30
Video Size: 640x480
Aspect Ratio: 4:3
Audio Bitrate: 128
Sample Rate: 44100
AC: 1
2 Pass: selected
Deinterlace: selected
SIDE NOTE: If you create videos often, you may take the OPTIONAL step to make a "Preset" in WinFF. If you only occasionally create YouTube videos, there is no need. The XML params you would use for a "YouTube preset" are-r 30.00 -vcodec libx264 -s 640x480 -aspect 4:3 -b 2000k -acodec libfaac -ab 128k -ar 44100 -ac 1 -deinterlace -- and yes, you will still want to check the 2 pass option before conversion.
ALSO NOTE: Audio enthusiasts are sure to point out that YouTube recommends MP3 as the preferred audio encoding method for video uploads. But it seems that using MP3 audio in an MP4 video returns a runtime error in Quicktime. And I just don't feel like installing yet ANOTHER media player. So the audio encoding method I use is AAC, which is the default for this conversion process and seems to work just fine. So no codec adjustments are necessary.
Now with these settings, convert the file. The resulting MP4 file will be just under 300 Kb for every second in length. If your video exceeds 5 minutes in length, the output will be larger than YouTube's 100 MB file size limit. Don't panic. There's now an easy way around this. Just use the YouTube multifile upload tool at http://www.youtube.com/my_videos_multiupload to lift the cap to 1 GB per file.
If you pass your source videos through WinFF with these settings, the MP4 file that is produced will look great in YouTube's "high quality" mode, and still very good in "standard" mode.
Hope this helps,
Bill M
http://www.sunfitters.com -
ty for this, i gotta try this one day
Originally Posted by billmi -
I can find no evidence to support that statement. Do you have a link?Originally Posted by billmi
Also, setting the framerate at 30 and deinterlacing is only called for if, 1) the source framerate is 30fps and, 2) it's interlaced and requires deinterlacing. If neither of those 2 preconditions are met, you're only degrading your video by using those settings. In my own case, with 140 videos uploaded none were 30fps and none required deinterlacing. Maybe you're talking about home movies or something similar. -
http://www.youtube.com/t/howto_makevideoOriginally Posted by manono
"We specifically recommend the MPEG4 (Divx, Xvid) format at 640x480 resolution with MP3 audio. Resizing your video to these specifications before uploading will help your clips look better on YouTube."
I just tested a video upload at 24 fps. Once YouTube was done with its compression, the only viewing option provided was "Standard Quality." But when I upload the same video at 30 fps, YouTube automatically generates two videos -- one in "Standard Quality" and another in "High Quality." You may have 140 videos uploaded, but YouTube is constantly changing the way it processes uploads. So what worked for 140 uploads in the past may no longer produce optimum results.Originally Posted by manono -
MPEG-4 isn't MP4, which is what you said they recommend.We specifically recommend the MPEG4 (Divx, Xvid) format at 640x480 resolution with MP3 audio. Resizing your video to these specifications before uploading will help your clips look better on YouTube."
So what? What does that prove? All 140 of mine are 23.976fps, uploaded as recently as yesterday. About 135 of them are available in High Quality (the &fmt=6 quality - 480x360 H.263/FLV). All 140 are available in the other High Quality (&fmt=18 - 480x360 H.264/MP4).I just tested a video upload at 24 fps. Once YouTube was done with its compression, the only viewing option provided was "Standard Quality."
In most cases they generate 3 videos.YouTube automatically generates two videos
Simply not true. Like I said, as recently as yesterday I uploaded 5 videos. All 140 were uploaded as XviDs (MPEG-4) with MP3 audio, their preferred format, and not MP4 with AAC audio which you're promoting. Maybe if you had uploaded that test video as an XviD, that High Quality option would have appeared. Also, I suspect if you check that test video of yours with KeepVid, it'll be available for download as a High Quality MP4.So what worked for 140 uploads in the past may no longer produce optimum results. -
Why do you button with a choice of high quality can not simply insert a film by adding an empty cage and typing in the URL bar &fmt=18 each film on youtube has its equivalent of stereo Now, each video is put to 2 times that of the X264 in just 2-pass.
http://www.youtube.com/watch?v=Pb22sOt4E_g&fmt=18
input video (UPLOADED TO YOUTUBE):
(MeGUI)
Format : MPEG-4
Codec ID : isom
File size : 29.3 MiB
Duration : 10mn 55s
Overall bit rate : 375 Kbps
Encoded date : UTC 2008-08-03 19:18:36
Tagged date : UTC 2008-08-03 19:18:36
Video
Format : AVC
Format profile : High@L2.1
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : avc1
Duration : 10mn 54s
Bit rate : 366 Kbps
Maximum bit rate : 4965 Kbps
Width : 480 pixels
Height : 360 pixels
Frame rate : 23.976 fps
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.088
Stream size : 28.5 MiB (97%)
Writing library : x264 core 60 r928M 4816918
Encoding settings : cabac=1 / ref=1 / deblock=1:-2:-1 / analyse=0x3:0x113 / me=hex / subme=5 / psy_rd=0.000000 / brdo=0 / mixed_ref=0 / me_range=8 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=1 / nr=0 / decimate=1 / mbaff=0 / bframes=16 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=0 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=366 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=1.00 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=2:1.00
Encoded date : UTC 2008-08-03 19:15:04
Tagged date : UTC 2008-08-03 19:18:37
Audio
Format : AAC
Format profile : LC
Format settings, SBR : Yes
Format settings, PS : Yes
Codec ID : 40
Duration : 10mn 55s
Bit rate : 7976 bps
Maximum bit rate : 29.0 Kbps
Stream size : 638 KiB (2%)
Encoded date : UTC 2008-08-03 19:18:37
Youtube HQ Reencode (&fmt=18) :
Format : MPEG-4
Codec ID : mp42
File size : 24.0 MiB
Duration : 10mn 55s
Overall bit rate : 307 Kbps
Encoded date : UTC 2008-08-04 06:33:18
Tagged date : UTC 2008-08-04 06:33:18
Video
Format : AVC
Codec ID : avc1
Duration : 10mn 54s
Bit rate : 273 Kbps
Maximum bit rate : 4187 Kbps
Width : 480 pixels
Height : 360 pixels
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.066
Stream size : 21.3 MiB (89%)
Tagged date : UTC 2008-08-04 06:33:19
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 10mn 55s
Bit rate : 30.0 Kbps
Maximum bit rate : 206 Kbps
Stream size : 2.34 MiB (10%)
So either youtube directs the average quality of the entire movie or the size of the output -
You are wrong dude. MP4 is MPEG-4.Originally Posted by manono
http://www.tech-faq.com/mp4.shtml
"MP4 is short for Moving Picture Expert Group-4. First published in 1998, MPEG-4 or MP4 was designed..."
You say that your videos are the &fmt=6 and &fmt=18 quality. Can you upload the video once and toggle between quality settings via the link at the bottom of the video?
Let me be clear. I'm not saying there aren't other workarounds. I'm only reporting what worked for me. -
The quality of this example is gorgeous. But to get there, you added 8:30 of deadspace (blank frames) at the end of your 2:24 length video. Oh, and you exceeded YouTube's 10 minute limit... which is now being imposed on all new YouTubers (Director or not).Originally Posted by falcionxx
Also, I looked at MeGUI, and it doesn't meet my standards of "simplicity" for the masses. Who wants a process that requires multiple tools and an inch thick manual to make work? Like a car, I don't need to know how the engine works in order to drive. I just want to slide in a key and turn the thing on.
For me, WinFF takes far fewer steps, saves production time and gets the job done. -
They recommend XviD or DivX which means AVI. The fact that you couldn't create MP3 audio for your MP4 should have clued you in. The video inside your MP4 is H.264 and not XviD or DivX, which are very different varieties of MPEG-4 video.Originally Posted by billmi
Let me be clear. I agree that other formats are accepted and can be converted. I'm only saying that nothing has changed as far as YouTube recommendations for the source video format (except the recommended resolution, because of the higher quality videos being offered now). I couldn't care less what you send them, or in what format. And maybe they do a decent job with them. I'm just saying that H.264/AAC MP4s are not what they recommend. And I also object to a couple of your recommended settings, where 30fps deinterlaced video will be completely wrong settings for the vast majority of videos. These bloggers you mentioned, I think either you misunderstood them or they're just wrong. Any links for one of these guys you care to share?
About the only thing that I've seen change is the horrible audio settings they've begun using which causes certain kinds of audio to give out with blasts of overly loud and distorted sound from time to time. If you upload music, perhaps you've heard for yourself the mess they're making of the audio these days. But there are workarounds for that now.
I can toggle back and forth between the Standard Quality (320x240 H.263/FLV, Mono Audio) and the &fmt=6 High Quality (480x360 H.263/FLV, Mono Audio). To get the &fmt=18 version of High Quality (480x360 H.264/MP4, Stereo Audio) you have to manually add &fmt=18 to the URL. I know of no way to automatically get the &fmt=18 version.Can you upload the video once and toggle between quality settings via the link at the bottom of the video?
Not just mine, yours as well.You say that your videos are the &fmt=6 and &fmt=18 quality.
Nah, they might say that 10 minutes is the max, but it's really 10:59. I'm not a Director but I have one that's 10:33, and no black frames at the end. It was uploaded 10 days ago.Oh, and you exceeded YouTube's 10 minute limit... which is now being imposed on all new YouTubers (Director or not).
If you want an easy all-in-one tool for video creation and conversion, you might take a look at XviD4PSPWho wants a process that requires multiple tools and an inch thick manual to make work? -
Thanks. What settings do you recommend in this tool? Can you provide a link to your video samples (for reference)? I would be delighted to learn a simpler way that achieves the optimum results.Originally Posted by manono
I don't use all-in-ones for YouTube video creation. I do it manually, frameserving with AviSynth scripts into VDubMod and creating XviD AVIs. But when I used XviD4PSP for a couple of other things (creating MP4 videos with H.264 video and AAC audio), I thought the ease-of-use, the variety of filters and settings available, and the results, were outstanding. I can't dispute frifox's recommendation of MeGUI as I've never used it, and don't know if he's tried XviD4PSP. But XviD4PSP uses top quality tools under-the-hood, so to speak, its results speak for themselves, and based on what little I know about MeGUI, MeGUI is a little bit harder to master than is XviD4PSP.Originally Posted by billmi
I don't know if you want to create XviD AVIs or MP4 videos, but you can easily create either. Open a file and set the output Format first, run down that main screen enabling what you want. If you want to specify 640x480, go into Video->Resolution/Aspect and set the resolution. Just look around and you'll figure it out, I think.
Baldrick wrote a guide (if you can call it that
) for its use:
https://forum.videohelp.com/topic352374.html -
MeGUI is a front-end to various AVC encoders, including x246. x264 is by far the best H264 encoder out there, and therefore MeGUI is able to provide the best quality H264/AAC videos given the same limitations than other encoders...Originally Posted by manono
nah, i havent used Xvid4PSP mostly because MeGUI provided me with more than satisfactory results... i dont know whats under the hood so i cant really compare it to other encoders.
PS: for filtering i prefer VirtualDUB, frameserved by AviSynth
Recommended upload video format for maximum sound quality on youtube
By waigy in forum Video Streaming DownloadingReplies: 25Last Post: 12th Sep 2010, 18:09 -
Youtube - bad upload quality
By therock003 in forum Newbie / General discussionsReplies: 5Last Post: 26th Jul 2010, 03:49 -
Poor quality following upload to YouTube-can anyone assist?
By acceleratorhams in forum Video Streaming DownloadingReplies: 1Last Post: 1st Jun 2009, 16:16 -
Poor Youtube Quality Upon Upload
By JohnSmith1981 in forum Video Streaming DownloadingReplies: 1Last Post: 20th Feb 2009, 13:54 -
Youtube HQ upload slow on normal quality
By seiun in forum Video Streaming DownloadingReplies: 2Last Post: 21st Sep 2008, 14:18
