Try watching this video with High Quality Option
http://youtube.com/watch?v=7odhW8op31U&fmt=18
I think it is just as high quality as our old HD methods if you use
the high quality option
Results 1,591 to 1,620 of 1969
Yes thanks. The full-frame clip is exactly 704x528 and the W/S clips differing amounts below that.Originally Posted by manono
The video isn't available. Do you remember the userID associated with that video?Originally Posted by cjwcorp
Did Youtube Block FLV videos? Because i uploaded a none HD Flv video and it failed to convert. or is it just me?
3 days ago i've uploaded FLV video and everything was ok.
"Death to General Midi!" - Necros/FM -
everything was okay as in, it stayed it its original form, or it got converted to LQ successfully?Originally Posted by Veeroos
YT processed the FLV, but in LQ, so i delete it
You mean the source was 1280x720 Resolution etc? We all know Youtube only encodes to 480x360 with &fmt=18Originally Posted by cjwcorp
plays stereo for me:Originally Posted by frifox
http://youtube.com/watch?v=EQVOwwQdGFc&feature=PlayList&p=24E42AA44E17AF4F&index=1
http://www.youtube.com/watch?v=EQVOwwQdGFc&feature=PlayList&p=24E42AA44E17AF4F&index=1&fmt=18 -
Well now that youve said it, they're gonna be like oh man We won't do thatOriginally Posted by cjwcorp
lol I know man....its been said many times that Youtube are watching this forum, and than you go along and say you made a script for SWF files? You might aswell just email editor@youtube.com and tell them the same thing! Anyways I doubt Youtube would have started accepting SWF all of a sudden..Originally Posted by venomite
Well, someone asked if they were still experimenting...
I'll edit it to nothing -
Then you should ask rajman and venomite to edit their posts tooOriginally Posted by cjwcorp
WTF? The inevitable has happened. Frifox's YT account was suspended a few hours ago while I received my last and final warning over posting HQ music videos. Damn Youtube!
Edit:
Those copyright notices are coming thick and fast right now. My second account got suspended due to claims by BlackHole Recordings (Tiesto's label). Yep, of all the DJs in the world, he's started removing vids from YT. Though I must say this is going to take ages because at last count, there were over 83,000 Tiesto and Tiesto-related videos on the tube. -
Yeah, post it here and I'm sure it gets closed as well.Originally Posted by gforce23
Today keepvid.com doesn't show to me the HQ flv version, only the LQ flv & HQ mp4 versions.
Does this mean that youtube has replaced the HQ flv (mono) version with the HQ mp4 (stereo) version?
Can you test it? -
It seems that by pressing the "watch in high quality" button, you still get the HQ flv mono version although you can no longer manually see it by adding "&fmt=6".
That's why keepvid.com does not find the HQ flv mono version. It still exists but they might have changed the "&fmt=x" code of it.
edit At least that's what I think. I'll do further testing in a while. -
you shouldn't mention that stuff either... YouTube will just block that alsoOriginally Posted by doomed
http://www.youtube.com/watch?v=iGwwwPQgZjc look, i've mixed 30hz sine wave with this track and YT compressor/limiter/whatever processed audio very nicely. Normalize your track to -3 DB, then mix it with -12 DB 10-30hz sine wave and sound will be much better.
No, I'm not violating any of their rules. I'm uploading only x264 .AVIs
I did further testing:
keepvid doesn't show me the &fmt=6 for ANY video
The high quality button still plays the &fmt=6 version
I have a xvid avi that I encoded to x264 and uploaded to youtube. I also uploaded the source file.
The x264 version has a "watch in high quality button" that plays the &fmt=6 version. I can also play this version by typing &fmt=6. It also has a &fmt=18 version.
The avi version (source) doesn't have a HQ button. Adding &fmt=6 does absolutely nothing. But it has a &fmt=18 version. -
After many tests I reached a conclusion that our put videos are being altered in the 2-pass mode (&fmt=18)(X264) and if we will add empty frames it is obvious that the quality will be left great this way it is looking out in theory.
http://youtube.com/watch?v=YlUq1NThtxc&fmt=18
video specifications which is seen on youtube
HQ(&fmt=18):
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 21.1 MiB
Duration : 10mn 0s
Overall bit rate : 294 Kbps
Encoded date : UTC 2008-07-27 17:04:43
Tagged date : UTC 2008-07-27 17:04:43
Video
Format : AVC
Format profile : Baseline@L2.1
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Codec ID : avc1
Duration : 9mn 59s
Bit rate mode : Variable
Bit rate : 272 Kbps
Maximum bit rate : 5121 Kbps!!!!!!!!!!!!!!
Width : 480 pixels
Height : 360 pixels
Display aspect ratio : 4/3
Frame rate mode : Constant
Frame rate : 25.000 fps
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.063
Stream size : 19.4 MiB (92%)
Title : (C) 2007 Google Inc. v06.24.2007.
Tagged date : UTC 2008-07-27 17:04:44
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 10mn 0s
Bit rate : 17.7 Kbps
Maximum bit rate : 248 Kbps!!!!!!!!!!!
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 44.1 KHz
Resolution : 16 bits
Stream size : 1.27 MiB (6%)
unimportant what format what resolution or anything still the medium video quality will always be on the 250-500kbit/s level
sorry for my English I justified with the translator -
I'm not sure what the fuss is all about. I uploaded a couple of videos yesterday and all three formats (LQ FLV, HQ FLV & HQ MP4) show up.
http://www.youtube.com/watch?v=8v3ZAzaq9y4
@doomed: Try uploading AVIs or MP4s with bit rates above 800kbps and 600kbps, respectively. You can check the exact bit rate using MediaInfo. The HQ FLV and MP4 versions usually show up within an hour, if not a couple of minutes. -
No motion videoOriginally Posted by gforce23
How I already said youtube is altering in 2-pass (VBR) if nothing is moving automatically the quality is raising the converter -
*Ack* So it seems. Can't say I'm surprised though. There was bound to be one complaint from an artist.
Recommended upload video format for maximum sound quality on youtube
By waigy in forum Video Streaming DownloadingReplies: 25Last Post: 12th Sep 2010, 18:09 -
Youtube - bad upload quality
By therock003 in forum Newbie / General discussionsReplies: 5Last Post: 26th Jul 2010, 03:49 -
Poor quality following upload to YouTube-can anyone assist?
By acceleratorhams in forum Video Streaming DownloadingReplies: 1Last Post: 1st Jun 2009, 16:16 -
Poor Youtube Quality Upon Upload
By JohnSmith1981 in forum Video Streaming DownloadingReplies: 1Last Post: 20th Feb 2009, 13:54 -
Youtube HQ upload slow on normal quality
By seiun in forum Video Streaming DownloadingReplies: 2Last Post: 21st Sep 2008, 14:18
