Did that, I just don't think the format works or I'm choosing a wrong setting somewhere that I'm not seeing.Originally Posted by venomite
Results 1,351 to 1,380 of 1969
I got a video working in 1 try. Tried several tests and all of them are working.
That works somewhat, except my VMuTube limits the bitrate to 350 kbps no matter how long the video is, ruining the quality. Also, it doesn't show the correct duration and I had trouble with zappa's method to fix it.
And that is with VMuTube 1.1?
For me it auto-defaults to try to get the overall bitrate under 350, whether it is 1 minute, 5 minutes, or 10 minutes.
Also, can I just combine default.flv and my VMuTube-made video and hex the padding instead of using flv reader? The program won't work for me anymore for some reason, it just spits out the exact same input file. -
Haven't tested VMuTube 1.1. Encode FLV using VMuTube v2.1. You can try whatever you want ^^Originally Posted by Assault
I was just sharing my method for those who were having trouble uploading.
Glitch in method: Must wait 4 seconds before video starts T_T -
Could you upload v2.1 or send me a link for it? I can't find it anywhere, I've been using 1.1. Maybe that's why I have problems, =/.Originally Posted by cjwcorp
MUST READ:
Stretch your video to a maximum of 10:57 using Sony Vegas. If your video goes over 10:57, YouTube will reject the file due to length of the video.
Your FLV file encoded from VMuTube will be 10:57. When you combine it with default.flv, your video will be 10:59(The maximum your video can be) -
CJW Entertainment's formula
1. Render using Sony Vegas (I used 480x360 resolution)
2. Run VMuTube (Output = uTubeVideo.flv)
3. Combine default.flv (480x360 default file) with uTubeVideo.flv
FLVBIND video.flv default.flv uTubeVideo.flv
4. Move into same directory as Zappa's FLV Reader and run through FLV Reader
5. Open up a Hexadecimal editor
~ Go down to the bottom of the script and click on the last cell (It seems to be 74 all the time)
Go to: Edit - Find - In Type select "Hex Bytes" (BYTE) - and enter the following value of 7 cells:
00 00 00 00 2f ff fb
and click Find.
It now will display the message: "A pattern was not found"
Click Ok.
Type (Shift+F3)
Change the previous 9 cells in your file to 01 ad 08 00 00 69 0a 10 e0
Save as an FLV file. (ready4upload.flv)
All Set!
Upload ready4upload.flv onto YouTube!
Here is my uploaded file with PROPER THUMBNAIL
http://www.youtube.com/watch?v=yQbBhrYW1z0
Here my youtube channel
www.youtube.com/cjwentertainment -
when prompted for target audio bitrate, type "0" and hit enter... in the next prompt you can change the bitrate limitOriginally Posted by Assault
H264? What would that mean?? I never knew........
But I have uploaded HD videos after the 17th ^^
http://www.youtube.com/watch?v=yQbBhrYW1z0 -
H264 is a highly efficient video codec that can provide impressive quality video under low bitrates... i used it in the following uploads:
- http://youtube.com/watch?v=7Yhu0Jc-W70
- http://youtube.com/watch?v=Y3TMouePCf8
- http://youtube.com/watch?v=IIDLGi60r08
the last video using H264/AAC i managed to upload was on 17th. after that it gets rejected by youtube. so i was wondering, has anybody managed to upload H264/AAC video to youtube AFTER 17th? -
I don't think it says how to upload in H264 here..
Though I would love to learn how to.
If 720p is possible, than why not 1080p? 1920x1200 resolution
What program do you have to use to try H264 out? -
He's saying to you and everyone else who type HD and HQ in their titles or descriptions to stop doing this and attracting the attention of YouTube with these labels. Of course you can do what you want, typing these things may get you more views, but out of respect for the community who want to continue uploading in high quality without youtube constantly stopping their methods, you don't have to be so selfish. I used to be the same way, but I've since removed my labels.Originally Posted by virtualgamesco
When using this formula, make sure to use the MULTIVIDEO Uploader... I've just tried uploading with the regular upload and it got rejected. MULTIVIDEO Upload for me has been 100% success rateOriginally Posted by cjwcorp
GOOD NEWS GUYS!
Spartacomp' New Team work meathod
The video limit doesn't have to be 4 mins or less: i have managed to upload a 6 min video:
http://www.youtube.com/watch?v=u01ttPSrHzw&eurl
I rendered this Still video using Sony vegas with the following specs:
640x480
25 framerate
320 kbps autio, 44,100
WMV format
Team work rendering Specs:
112 audio bitrate
640x480
25 framtrate
100 keyframe interval
+ i used .bat #0.9a
Voila!
hexing duration also works perfectly! -
frifox method 1.7 still works but it goes LQ in a minute. How do we fix that?
Frifox, thanks for that tip with the 0 audio bitrate, I remember seeing that when scanning through the .bat but I guess I ignored it >_>
cjwcorp, did you run into a problem where it said 'Add a title and description for: yourvideo.flv' while using the multi-uploader? It isn't working for me, at all I think.. -
Well I dont think putting HD or HQ in the title makes any difference, there are thousands of videos uploaded everyday that has either HD or HQ in the title, so I dont really think Youtube looks at every single video hoping to find one of our HQ methods being used.Originally Posted by adamlui
And to Frifox same thing with me, last H264 video successfully uploaded was the 17th for me to: http://www.youtube.com/watch?v=t5CMccdVgS4
H264 is the best as Frifox said, just see this video I uploaded a week ago, its <350kbps so no need for any hexing: http://www.youtube.com/watch?v=UoKwihE0tNU -
btw, uploaded this today:
H264@600Kbps, AAC@128Kbps:
http://youtube.com/watch?v=pEBN4ZTRyF4
the only problem i couldnt tackle is that the fake duration still shows in the player. apparently youtube made their timestamp/duration checking much harder to bypass
How? same as usual, but for timestamp hack, for the last audio tag, change DataSize to "00 00 69" and timestamp to "0A 10 00" (or to whatever you wish)...
AudioTag = "08 DD DD DD TT TT TT"
DataSize = DD DD DD
TimeStamp = TT TT TT -
when i encode to flv with VmTube 2.0 i dont get high quality vids.. here's a screenshot:
Ive just managed to upload a H264 video again....and it shows correct duration =)
http://www.youtube.com/watch?v=fKrZD_S3hPI -
I did a few tests and for this video I just changed the last timestamp to '04 90 00' and it went through fine after re-uploading it like 4 times
lol, i also changed the last timestamp (to 0A 10 00) but player shows the FAKE duration :S
Recommended upload video format for maximum sound quality on youtube
By waigy in forum Video Streaming DownloadingReplies: 25Last Post: 12th Sep 2010, 18:09 -
Youtube - bad upload quality
By therock003 in forum Newbie / General discussionsReplies: 5Last Post: 26th Jul 2010, 03:49 -
Poor quality following upload to YouTube-can anyone assist?
By acceleratorhams in forum Video Streaming DownloadingReplies: 1Last Post: 1st Jun 2009, 16:16 -
Poor Youtube Quality Upon Upload
By JohnSmith1981 in forum Video Streaming DownloadingReplies: 1Last Post: 20th Feb 2009, 13:54 -
Youtube HQ upload slow on normal quality
By seiun in forum Video Streaming DownloadingReplies: 2Last Post: 21st Sep 2008, 14:18
