I use teamwork method, succeed two time, then got "fail to encode" many time
so I goback to use the FlvBind method(still succeed last week), also failed
Results 1,321 to 1,350 of 1969
I just uploaded 2 videos using C243. It seems to be working right now
Originally Posted by harmster
LOL...If Truth is OPTIONAL
Error is JUSTIFIABLE -
I attempted the Teamwork method. I got the following error when clicking on the BAT for my original.wmv:
system cannot find path specified
missing operand.
it's a 3 minute wmv. The original file is 640x480. I chose 96 audio bitrate, 640x480 resolution, 25 frame, 100 key interval. Spartacomp.flv was not created and I got the error message. I used the 640x480 default.flv. -
Thats the Problem right there! your "orginal" video is supposed be an Avi file instead of WMV, without the video being wmv, the process will error!Originally Posted by Mistahkleen
nextime please read instructions carefully before asking questions. -
You know what makes me mad, when people put HD or HIGH QUALITY or w.e you should stop doing that, then there is a chance the method will go bye bye, just like vmutube and imutube, i never put [hd] or [hq] or w/e cuz i don't want ppl to ask, and i don't want it to go away, u know. so c'mon ppl if u still want this to live longer stop putting [hq] in your video title, and stuff!!!
You go to the very bottom tothe last line , and you replace the last 9 cells with the number on the .bat file you chose to run...example:Originally Posted by Spritemoney
if you ran bat 01 = 00 e6 08 00 00 69 01 dd 18
if you ran bat 02 = 01 36 08 00 00 69 02 c7 7b
if you ran bat 03 = 01 00 08 00 00 69 03 b1 de
if you ran bat 04 = 02 7e 08 00 00 69 04 9c 27
if you ran bat 05 = 05 54 08 00 00 69 05 86 be
if you ran bat 06 = 02 16 08 00 00 69 06 70 ec
if you ran bat 07 = 01 ad 08 00 00 69 07 5b 4f
if you ran bat 08 = 03 9c 08 00 00 69 09 30 14
if you ran bat 09 = 01 ad 08 00 00 69 0a 10 e0
if you ran bat 09a = 01 ad 08 00 00 69 0a 10 e0
cell being a two degit number: for example: "02" "76 "54" are three cells of 2 digits -
Originally Posted by venomite
Hahaha, you're funny. I used a WMV because that what the instructions said to do. I can read, can you? It's obvious that there is something else I'm missing. But I followed the instructions to the tee. -
I finally got the Teamwork method working, but what i find weird is that all of the time i upload a video their is lots of block's added to it.
Anyways here is my vid.
http://www.youtube.com/watch?v=WRTZpUkyQVg -
Hmmm... The video i uploaded i noticed that after a while the block's a saw were gone is it because it needs a while to process or something?
Very good that it works, but the duration is wrong, low fps and a lot of buffering.
Better for you would be to upload your video at 640x480 @ 30 fps and obtain YouTube's high quality option. That's my suggestion.
btw, Try Runnin that ".bat" file as administrator.Originally Posted by dzvero007
venomite, that'd be for rendering with Sony Vegas, and it is optional. You can render it as .wmv in Vegas or .wmv in Windows Movie Maker, and they will both work.
Also, dzvero, people are trying to bypass youtube's re-encoding, why do you keep suggesting not to, let people do what they'd like. >_> -
Really? If you mean the tool by "freakydeakyalive", I just recently got "Failed to convert" 3 times in a row...Originally Posted by cjwcorp
Well I dont use Spartas method so I can do what I want, Ive been uploading HQ vids before the 'Teamwork' method came along.Originally Posted by Assault
1280x720: http://www.youtube.com/watch?v=qEbT1rPFKxA
1280x720: http://www.youtube.com/watch?v=bmekYEI2tiw
720x416: http://www.youtube.com/watch?v=SCnP4-MRJzY -
You HEX edit the second-to-last timestamp, right Rajman?Originally Posted by rajman
That I couldnt get to work, I did something else on those videosOriginally Posted by virtualgamesco
When I said that, I was talking about him being angry about people putting HIGH QUALITY or whatever in the video titles, nothing else.Originally Posted by rajman
I just got a 'failed to convert' with the w16 method...
This is serious. -
Whoops, never mind...Originally Posted by virtualgamesco
Okay, I hexed everything properly, bitrate is 310 kbps and the length is 8m 2s.
I used On2 Flix Pro to encode the flv, then did the rest manually. I think YT might be changing things up, because a video I uploaded yesterday using this same method worked fine. Now it's gotten the 'Failed to convert' message about 10 times in a row with it set to private. I'll keep trying and see if I just have bad luck.
Edit: Nope, I don't think On2 works, 15-20 upload fails in a row on private. -
Try making your rendered files Resolution the same as your default.flv's resolutionOriginally Posted by Assault
Recommended upload video format for maximum sound quality on youtube
By waigy in forum Video Streaming DownloadingReplies: 25Last Post: 12th Sep 2010, 18:09 -
Youtube - bad upload quality
By therock003 in forum Newbie / General discussionsReplies: 5Last Post: 26th Jul 2010, 03:49 -
Poor quality following upload to YouTube-can anyone assist?
By acceleratorhams in forum Video Streaming DownloadingReplies: 1Last Post: 1st Jun 2009, 16:16 -
Poor Youtube Quality Upon Upload
By JohnSmith1981 in forum Video Streaming DownloadingReplies: 1Last Post: 20th Feb 2009, 13:54 -
Youtube HQ upload slow on normal quality
By seiun in forum Video Streaming DownloadingReplies: 2Last Post: 21st Sep 2008, 14:18
