Thanks a lot for that man, that cleared up the purpose of the extension of the time. For me 350kbps is actually enough - I would like 160kbps MP3 stereo audio and around 150kbps video, I might change my settings a bit to sort that out.- The -b 100 command, with that you set the video-bitrate to 100 kbit/s, which is quite low.
- The time duration extension is a way to fool the average bitrate;
Hehe yes it was, oops.typo?Technically then, all I should need to do is run hexalter and it should bypass encoding? For some reason it's not working for me, perhaps because I am encoding video too rather than just the picture you are putting on your vids?
I am finding that after encoding with FFMPEG, Mediainfo is only showing an audio bitrate and not a video bitrate...I see someone else has experienced this above. This doesn't happen with Moyea Flash MX so I tried HexAltering the res on one of it's output files...it still gets encoded to LQ after ~10 mins.Poocakes.
Any thoughts are hugely appreciated, thanks.
				Results 661 to 690 of 1969
	cool, I saw it, but I just noticed that HQ version isn't any better, guess I have to learn how to hack the bitrate too:POriginally Posted by frifox
 frifox, can you tell us what's the command you use in FFMPEG to encore this EVE video?
 My video is only 23secs long, so all I need is encore it to FLV with high bitrates and bypass the YT re-encore step.
 Thanx again.
	Hmmmmm I thought the thumbnail was black beacuse it must have been loacted somewhere in the padded frames, But it isnt! I just uploaded a video that has no padding or fake time duration (as it is under 350kbps) and the thumbnail previews for all 3 possible were still black =( Does anyone know why this is? or is it just beacuse command 'hexalter uTubeVideo.flv 0x120=0x08,0x06,0x11,0x1F' does this and theres no thumbnail possible using this method?Originally Posted by rajman
 Heres the video btw: http://www.youtube.com/watch?v=jKGm6PT_Zvc
	[quote="NiGHTsC"] I'm getting good results using frifox's original VMuTube tool method. I'm using it just as before- 1. use Vegas to create a padded 10:59 video (original is 3-5 minutes or so), 2. render as avi H.264, 3. run VMuTube.bat to create flv. Mediainfo reports it has a 345 Kbps rate but it does play at a faster rate when using &fmt=18 on YT. Until the thumbnail problem is fixed, I'm going to use the old method and &fmt=18 with playbackOriginally Posted by frifox
	Ohh I cant believe how n00by I was on my last comment  the thumbnail will appear, only when a picture is exactly in the middle of the video BUT it must be in the top left corner at dimensions 16x12...so I guess thats why Frifox's vids have the pixelated thumbnail! the thumbnail will appear, only when a picture is exactly in the middle of the video BUT it must be in the top left corner at dimensions 16x12...so I guess thats why Frifox's vids have the pixelated thumbnail!
	by the way YT did 'maintenance' last night, June 16. Anything can change after these maintenance things
	HQ is still alive, even though YouTube did some Maintenance IMtube 2.1 still goes into superb HQ production. Great!!
 watch : http://youtube.com/watch?v=1kP0gNYmDCIIf Truth is OPTIONAL
 Error is JUSTIFIABLE
	not only that I uploaded a vid using VMuTube 1.1 about 3 hours ago and it's still untouched
	using VMuTube 1.1? okay, but did u hack it maybe just like the 2nd ver of VMuTube which implies some hacking tools..Originally Posted by mikejf
 mmm.. now i understand, untouched means u add the &fmt=18 right, it same goes to my previous Vid : http://youtube.com/watch?v=-6Nc_A6vIuI (VMuTube 1.1) but if u notice, the sound encoded into MONO... huhh!! i'm sick of this..
 can u show me ur video mikejf?If Truth is OPTIONAL
	I just uploaded two videos using VMuTube 1.1 as well, and both are still untouched.
 Golgota, you don't have to do anything except follow the VMuTube instructions to get it to work right now. However, chances are it won't last long. And untouched means it bypasses the YouTube re-encoding, and has nothing to do with adding '&fmt=18'
	Thanks All especially to the "Expert".  .information here are "MORE THAN ENOUGH" for me to alter the old version IMUTUBE and VMUTUBE...and it works... my videos and still videos + STEREO audio track are still intact for more than 12 hrs now...hopefully still the same after 24 hrs ..  (I noticed ppl unable to "search" youtube for this "hack" type video even i try myself after 12hrs upload time and still can find my videos-anybody experience the same problem???) .information here are "MORE THAN ENOUGH" for me to alter the old version IMUTUBE and VMUTUBE...and it works... my videos and still videos + STEREO audio track are still intact for more than 12 hrs now...hopefully still the same after 24 hrs ..  (I noticed ppl unable to "search" youtube for this "hack" type video even i try myself after 12hrs upload time and still can find my videos-anybody experience the same problem???)
	more or less, i use same command for pretty much all of my uploads:Originally Posted by NiGHTsC
 Encode Video
 Encode Audio:Code:ffmpeg -i video.avs -pass 1 -an -vcodec flv -b 250k -g 150 -cmp 2 -subcmp 2 -mbd 2 -flags aic+cbp+mv0+mv4+trell+umv+gmc+obmc video.flv ffmpeg -i video.avs -pass 2 -an -vcodec flv -b 250k -g 150 -cmp 2 -subcmp 2 -mbd 2 -flags aic+cbp+mv0+mv4+trell+umv+gmc+obmc video.flv
 Mux Audio+Video:Code:ffmpeg -i video.avs -vn audio.wav lame audio.wav audio.mp3 --abr 100 -q0 --resample 44.1 --lowpass 18
 Code:ffmpeg -i audio.mp3 -acodec copy -i video.flv -vcodec copy uTubeVideo.flv
 to make PNG+MP3 combo, i use different command:
 Code:ffmpeg -i audio.mp3 -acodec copy -loop_input -f image2 -i video.png -vcodec flv -r 1 -g 10 -qscale 2 -shortest uTubeVideo.flv
	just reporting that I have uploaded three vids now with old VMuTube 1.1 method and last two got quickly re-encoded, however the first one still untouched (7 hours now). Nothing different about it as far as I can tell. I think some just slip through sometimes.
	Use Hexalter after processing with VMuTuve ... I notices there's a slight changes on video quality after 14hrs I uploaded the video but audio still untouched (in STEREO-not sure if my footage already being process by YOUTUBE but definitely there's changes on video quality)Originally Posted by mikejf
 Will wait for the video to pass 24hrs test..
 For still test image using IMUTUBE with hexalter also in "great shape"....till now.
	Hi guys, my uploaded video report:
 VMuTube 1.1 Production
 Death Race Trailer. I resize it into 480x360 & do the same thing (VMuTube 1.1)
 Got encoded after 2mins Uploaded.. :'(((
 http://youtube.com/watch?v=pB8PrgcXq2QIf Truth is OPTIONAL
	Why are you all trying this still? It has been known for ages now.Originally Posted by Golgota
 There's another method that bypasses the re-encoding of your upload:
 https://forum.videohelp.com/topic336882-630.html
	note to everyone:
 plz dont report your video here as HQ unless it stayed HQ for more than 24hrs! patience my friends, patience
 going back to topic, i think hex-editing the resolution is not required anymore. there is a better way
 but before i start blabbering about this "better" way, first i'll see if the videos uploaded with that "new" way stay HQ for more than 24hrs... so far they stayed HQ for 7hrs, but i'm pretty confident that it will work in the long run too...
	Originally Posted by FoxLockedOriginally Posted by harmster
 if you dont see it, then you didnt read the topic close enough
	Is it this???Originally Posted by frifox
 it seems that youtube leaves FLV's with resolution less than 16x16 in original format without converting to LQ... so far all of my 16x12 uploads stayed HQ
 that got me thinking, how does youtube check for resolution? after some experimenting i found that youtube apparently checks first video packet's resolution and takes that as your video's resolution.
 by simply faking first video packet's resolution to something like 16x12, youtube will leave your uploads in HQ... which is pretty much what babymammoth's w16 method is all about =D
 EXAMPLE: http://youtube.com/watch?v=_S0-mhiTd9I
 PS: video packet's resolution is a set of 4 hex-pairs, if format "WW WW HH HH"... its the 16th hex pair after the 09 (start of the video packet)....
 PS: 16x12 would be "08 06 11 1F"
	Ok So umm... im a noob here and i don't understand this. What program are you guys using to convert your video to flv??
	Frifox how u get the thumbnail correct on this video of yours?
 http://www.youtube.com/watch?v=VqYOcUzhfVk
	Ohh ok, but what did you do if you do mind saying? Cant still be the 16x12 thumbnail can it? If not what did you do?
	something along the lines of:
 http://www.youtube.com/watch?v=SR6WvJNlKQ8
	This has already been discussed extensively in these threads:Originally Posted by FoxLocked
 https://forum.videohelp.com/topic336882.html
 https://forum.videohelp.com/topic345987.html
 https://forum.videohelp.com/topic346256.html
 https://forum.videohelp.com/topic351166.html
 I highly recommend reading these before repeating questions that have been answered time and again by many others before you.
	That was awesome, never knew you can merge different frame rate FLV's together XD Can you provide any help on how to get the thumbnail right? Ive got the HQ vids working fine but the thumbail is a pain in the backside and I cant get around it! I know about the 16x12 in the top-left corner but we just get pixelated thumbnails =( And this vid: http://www.youtube.com/watch?v=VqYOcUzhfVk Has a normal thumbnail, how did you do that one so right?Originally Posted by frifox
  Recommended upload video format for maximum sound quality on youtubeBy waigy in forum Video Streaming DownloadingReplies: 25Last Post: 12th Sep 2010, 18:09
  Youtube - bad upload qualityBy therock003 in forum Newbie / General discussionsReplies: 5Last Post: 26th Jul 2010, 03:49
  Poor quality following upload to YouTube-can anyone assist?By acceleratorhams in forum Video Streaming DownloadingReplies: 1Last Post: 1st Jun 2009, 16:16
  Poor Youtube Quality Upon UploadBy JohnSmith1981 in forum Video Streaming DownloadingReplies: 1Last Post: 20th Feb 2009, 13:54
  Youtube HQ upload slow on normal qualityBy seiun in forum Video Streaming DownloadingReplies: 2Last Post: 21st Sep 2008, 14:18
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
