All of mine attempts at hexing the audio packet get reencoded as well.
It's not the same file because YouTube Injector tags it with its own metadata.Originally Posted by ibananapandas
Results 571 to 600 of 1969
Apparently these methods have been nerfed again June 2nd 08 aprox Around evening GMT+1.
Hexing the width returns an encoding error after processing and Hexing the TimeStamp videos will not work anymore.
Apparently those videos got re-encoded. Mine's are still up, but 24 hours have not passed yet, however I am expecting that only videos with extended duration are getting re-encoded.
Also note that the only thing YT does to untouched FLV's is replacing the headers. -
YT/Google don't have to tighten anything, all they have to do is convert all uploads, and skip checks. Which is exactly what they do these days.Originally Posted by mikejf
You can be lucky for a little while (for as long as the new encoder scripts land on your new video, after which it's being converted). And the reason it takes a while is simply because the servers have a huge backlog or lag from having to encode so many videos at one time.
If you want online video to be in higher quality and with stereo audio, either host them yourself:
http://jeroenwijering.com/?item=Embedding_Flash
or join dailymotion or vimeo;
http://www.dailymotion.com/cluster/tech/hd/1
http://vimeo.com/hd -
That's just a coincidence. They use simple load-balancing. If it's real busy, your speed will be capped in a way that Google can still serve as many users at one time as possible. There really isn't a bottom speed set for that, as far as I can tell.Originally Posted by frifox
but what I think is happening with frifox's new method is not trying to skip encoding, it's trying to error out the encoding (so that flv remains intact, although metadata has changed). So YT is encoding all vids, but some error out (which is what we want) during encoding.Originally Posted by bayme
here's what I think happens:
1. you upload a HQ flv
2. it's placed in your video account folder but YT displays "Please wait...processing"
3. it sits unchanged in a waiting que
4. finally it gets 'processed'- and the encoder begins (this seems to happen withing 10 minutes)
5. metadata info is updated on the original (with flvtool2)
6. now the encoder begins to create a new flv, but with YT specs (480x360, mono, etc)
7. IF no error occurs the encoder reads all of the original data (video + audio), gets to the end, and has created a new flv which replaces the original
but IF an error occurs during encoding (what we want) the encoding is aborted (or certain steps within encoding), and the original video and audio stays intact. The encoding completes, but it had errors during the processing, and since some normal vids sometimes have errors, the encoding completes anyway and updates user page from "Please wait...processing" to "Live!". The encoder 'thinks' it's successfully encoded the video and the flv has been changed, but only metadata, so that when it plays it plays the original video + audio. -
i believe some of you misunderstood what i tried to tell... modifying timestamps does NOT guarantee your uploads to stay HQ, this method is only used to fake the duration.
the purpose of faking the duration is exactly the same as padding the video with black frames... to make your high-bitrate videos average out to less than 350Kbps
talking about youtube... i simply cant understand why on earth are they are still allow FLV videos to pass through untouched? simply re-encoding everything that we upload is a much simpler and effective solution.... :S
and as bayme said, Vimeo.com and DailyMotion.com are MUCH better alternatives to youtube... -
As long the encoder doesn't return any errors, but still encoded some part of the video wrongly, nothing will be shown and the video will be passed through. By modifying any FLV data you are misleading the encoder and making it pass through success status with a wrongly encoded or untouched file. This program isn't bugfree. Therefore YT needs to implement their own filechecks. That's what they have to be heading for. Catching errors.
i use dailymotion aswell and it doesnt recode flvs with bitrate under 350, also dailymotion "streams the videos"faster than youtube.Originally Posted by frifoxI love it when a plan comes together!
dailymotion very slow in my country, but I still use it for a period of time because of its stereo sound(96kbps mp3, and youtube only 64kbps mono)
though dailymotion has HD now, but you have to become a "motion maker"
and the file must be chek first by dailymotion team before published.
vimeo can not publish TV show.
So, since youtube's &fmt=18 trick still works(better video and stereo sound), I still will use it now. -
does adding &fmt=18 allow stereo on YT? Or is that the same as setting your account to play high quality?
Comparison of Normal Youtube vs Youtube High Quality:does adding &fmt=18 allow stereo on YT? Or is that the same as setting your account to play high quality?
http://blog.jimmyr.com/High_Quality_on_Youtube_11_2008.php -
That site is posting really strange values (lies, even).Originally Posted by babymammoth
The format 18 version simply copies source framerate. Better yet, I have yet to see YT resample frames. It will only change framerate if you feed it really obscure values. As long as you're feeding YT between 14 and 31 fps, it will never alter framerate, as far as I have noticed anyway.
Format 18 has stereo LC AAC audio. It even posts 2 channel audio when you feed YT only 1 channel. Problem is that their audio post-processing for fmt 18 is kinda' flimsy to say the least. You just can't tell what to expect from it, and so it is in essence not very reliable. -
So, how do I find the time stamp for audio/video? Here are examples from the very top and very bottom of the file opened with HxD hex editor.
brassplyer, editing the timestamp will not prevent YT encoding, it just delays it. So, by itself, it's not recommended. However, if you still want to try, I might be able to find it if you tell us the length of the video (min
ec)
This is the video frifox posted and 4 days later it's still unchanged
http://youtube.com/watch?v=ksM8qucczvU
The flv file the screenshots are of is 5:17 -
I dont see the typical 08 pattern I'm use to seeing in a flv, and it's allready been edited to 11:00 so not sure where the 11:00 time stamp is, sorry. Also, as frifox hs said, timestamp edit alone will not prevent encoding, frifox uses another method.Originally Posted by brassplyer
If there are only a few methods left for YT not to convert videos, please disclose them or kindly stop this hypcritical carrot-waving fagotry.
Otherwise this thread has lost its purpose. -
I was just reporting my test results about the timestamp method. At first I thought it was working, because it was untouched for many hours. But after 24 hrs they were re-encoded, so it fails. Spent a lot of time testing, so others would not have to.Originally Posted by kodaismahhussy
carrot waving fagotry...Originally Posted by kodaismahhussy
i think it's called secrecy,
because youtube have been somewhat like killjoy pricks lately.
i've not tested anything in ages,
but if you ask frifox nicely, maybe you;ll get a look into the secret circle.
tripp -
secret circle...oh god...the perfect bait
lmao@youboobs
Dear FriFox Darling
Can u at least give us a clue... how to maintain the STEREO audio + HQ.. and will try our best to figure out where to start experimenting
TQ -
How to find this "WIDTH" thing in HEX...tqOriginally Posted by astin
How is the video below being uploaded and maintaining stereo? It's not even an HQ video. (Not my type of music)
http://www.youtube.com/watch?v=ca9GJ6mMxLw -
It was posted on May 3rd, before the old method was disabled.How is the video below being uploaded and maintaining stereo? It's not even an HQ video. (Not my type of music)
There are a lot of stereo videos floating around from that time:
http://www.youtube.com/watch?v=0J9s50G-veg
http://www.youtube.com/watch?v=TvFvPKPqCRg
http://www.youtube.com/watch?v=-0OhD-C94UQ
http://www.youtube.com/watch?v=5Ocg1uUjZOs
I have one on my own youtube account from June 1st that stayed stereo. Don't have a clue as to how - it seems to be a random thing:
http://www.youtube.com/watch?v=WL-rAlsaCpg -
Ok, first to say, i think that YouTube doesn't encode all videos over 350 kbps to mono.
I've uploaded 2 videos (songs) which were both audio and video over 350 kbps (normal flv) and YouTube does not re-encoded their. They are in stereo.
http://youtube.com/watch?v=CYJwn-sQP8I
http://youtube.com/watch?v=J_HnwB7I_rA
When I uploaded these songs on YouTube, I didn't knew they are going to be re-encoded to mono. I was newbie(lol)... but now, afterall, I'm surprised they're still in stereo.
Maybe some videos by random don't turn to mono, or it might have another way to bypass? I don't know... could somebody explain ? -
http://www.youtube.com/watch?v=RO1SysI0m78
This video is a OK quality video
looks good huh?? I didnt use any hacks to do this.
I was bored so i just wanted to post this up.
Im still doing more tests to see if i could upload Better quality -
Well, seems like you still added a lot of black to get higher bitrate towards the actual video. Is youtube itself also using variable bitrate?
Recommended upload video format for maximum sound quality on youtube
By waigy in forum Video Streaming DownloadingReplies: 25Last Post: 12th Sep 2010, 18:09 -
Youtube - bad upload quality
By therock003 in forum Newbie / General discussionsReplies: 5Last Post: 26th Jul 2010, 03:49 -
Poor quality following upload to YouTube-can anyone assist?
By acceleratorhams in forum Video Streaming DownloadingReplies: 1Last Post: 1st Jun 2009, 16:16 -
Poor Youtube Quality Upon Upload
By JohnSmith1981 in forum Video Streaming DownloadingReplies: 1Last Post: 20th Feb 2009, 13:54 -
Youtube HQ upload slow on normal quality
By seiun in forum Video Streaming DownloadingReplies: 2Last Post: 21st Sep 2008, 14:18
