				Results 31 to 60 of 1969
	So it's an encoder, OK. Well, I just encoded an .mpg file but I can't encode an .avi file. How do I do that? Also, what's that in the 'User VIDEO Options' box?
 By the way, in the original guide in this thread, I was able to use the hex editor to edit .flv files that I encoded using TVC and Adobe Elements.
 How do I get an .avi file loaded into avanti? Thanks!
	no need to convert the mpg file into avi, just open the "folder" icon next to the "1" in red in the picture above, select the mpg file and avanti will acept and convert it. I love it when a plan comes together!
	I know that more info is needed to help me so here it is. I HAVE to be doing something wrong.
 Click here for an .mpg clip of this file.
 Click here for the avanti .flv file that I uploaded to youtube.
 Click here for the youtube clip I uploaded from the avanti file.
 Click here for the TVC .flv file that I uploaded to youtube.
 Click here for the youtube clip I uploaded from the TVC file. (This clip was exported from Adobe Premiere Elements as an .mpg file because I wanted to tweak the color and contrast). The original file is 16:9.
 I entered '345' in the bit rate box in Avanti but the encoded file said it was '487' before I ran it through HexEdit. Please let me know if you need anymore info. I appreciate any help that anybody is willing to offer. I hope that I am at least on the right track.
	i havent tampered my flv files, if you look at my fisrt pic youll se ive put 294 for video and 48 for audio as bitrares. 294+48= 342. i ended up with a bitrate of 348.Originally Posted by Captain Satellite
 if you follow my values ypu wont have to "hexefy" your flv.
 what is the problem you're facing? if you want 128k for audio youll have to reduce you video bitrate a lot...... loosing qualityI love it when a plan comes together!
	Ok, I see. I don't think that accounts for the quality of my youtube upload, does it? As I understand it, can't I maintain the higher audio bitrate if I hexedit, therefore losing nothing?
 My reason for the post is that compared to the other youtube uploads in this thread, mine looks like crap. Is that as good as I'm going to get considering my source?
 Thanks for the reply.
	My 2 cents:
 Not everyone has a fast internet connection, your source file has a duration of 30 seconds and the file you uploaded to youtube "weighs" 12 megs, to us on 512k connection is a nighmare to watch it because it takes so much time to load. i understand that you want people to see the audio quality but 12 megs for a 30 second clip. If you entend to share your videos remember that.
 your video(hexefied)30sec=12megs ---> http://youtube.com/watch?v=p-KmpeNmulk
 my(yours, 350k)) video 30sec= 1.27megs ----> http://www.youtube.com/watch?v=p-hJbu3MkZo
 by the way i think your video on youtube looks great.I love it when a plan comes together!
	ooopos, i think you gave the wrong link for the mpg because the one i downloaded has only 30 seconds duration I love it when a plan comes together!
	Click here for what I have now after more experimenting. Now I'd like to learn more about 45tripp's method. I'd like to undertstand what is going on in Steps 1 and 2. Does it work in conjunction with avanti?
 Sorry your connection is slow, but I think most people that watch videos online have a high speed connection. Thanks for the help - I couldn't have gotten this far with out you! (I honestly think this is as good as it is going to get).
	i disagree and WORLDWIDE STATS confirms it, at 350k (youtube bitrate limit, wonder why?) the video goes smoothly without hickups.Originally Posted by Captain Satellite
 the video looks good, but it freezes for a few seconds every 3 seconds.(net speed)
 No need to thanks thats what the forum is for
 Steps 1 and 2 are for people that like to use ffmpeg (the engine behind avanti) with commnad lines (Dos "alike"), Avanti is a program made for users that dont like to use command lines(me), youll get same quality with either method as long the settings are the same.I love it when a plan comes together!
	See!
 You managed just fine.
 Of course avanti can encode avis...Originally Posted by Captain Satellite
 can't really tell what you are doing wrong without more info.
 "user video/audio options" is essentially access to the commandline.
 cutting it rather fine.Originally Posted by ricardouk
 I remember 342k being the max combined audiovisual elementary bitrate. I think I had one fail as it hit the 350k when muxed.
 That's the point.Originally Posted by Captain Satellite
 Control!
 Here audio has priority...
 You should be willing to sacrifice video.
 Your source does not help. Fine detail, in the focus area. Already got ringing...Originally Posted by Captain Satellite
 Not as compressible as you'd like.
 That's what filtering is for.
 You can filter to make your source more compressible.
 Which is the answer to the DV question, i think, Ricardo asked. DV can be ugly, noisy, shaky... not nicely compressible.
 Also a lot you can do when in control of the camera...
 That shirt is not helping.
 Your clip didn't look like crap.
 The worst thing about it was the messed up aspect ratio.
 It sounds good too.
 I owe you a dollar!
 Step 2 is encoding.Originally Posted by Captain Satellite
 You've done that just fine.
 Step 1 is the more complex part. (noted optional and advanced)
 Source prep.
 Inverse telecine, de-interlacing, and so on...
 You have a progressive clip, so that was one less worry.
 You could benefit from some filtering though.
 Yes it works fine with Avanti.
 Avanti is set up to work harmoniously with avisynth.
 btw
 Ricardo do you not have avisynth installed?
 I noticed the red warning in avanti about the ffmpeg/avisynth combo not found.
 That's not a problem anymore, so I assume you don't have avisynth installed or have a filter in the plugins folder you shouldn't. if there's a problem, report in the thread to Chris.
 Untrue.Originally Posted by Captain Satellite
 I'm with Ricardo.
 I'm sure you know your target audience better than we do though.
 Anyway,
 filtering is an art, or fine game...
 and you have to decide when it's worthwile and how much time the source deserves...
 I just played with a few simple things.
 noise reduction and blur.
 i liked the way you went with colouring, but thought it heavy.
 dropped framerate all the way to 20fps. No heavy motion here. Can easily half the framerate I'd say.
 encoded with the same settings you first posted.
 http://www.youtube.com/watch?v=uVZiFDF0m_A
 gl
	Thanks for taking the time to answer my post, 45tripp. I got the .avi to work after all, BUT, I tweaked the color and contrast in APE and exported the file as .mpg. I've always enjoyed a saturated picture, personal preference I suppose.Originally Posted by 45tripp
 I would like to learn more about this. Are there other guides that can teach me how to use this feature?Originally Posted by 45tripp
 I've tried to go lower than 700 kbps but the picture is blocked. That's why my final file is 19.5 mb.Originally Posted by 45tripp
 I don't know what ringing is, sorry.Originally Posted by 45tripp I would love to learn  more about filtering. Is that what I would use avisynth for? Is there a good guide for that? I shot the video so if you could suggest anything that I should be doing on that end I could try that. I just grabbed a shirt, I agree! I would love to learn  more about filtering. Is that what I would use avisynth for? Is there a good guide for that? I shot the video so if you could suggest anything that I should be doing on that end I could try that. I just grabbed a shirt, I agree!
 I suppose "crap" is a stretch. I'm comparing it to your stuff, so in comparison it looks like crap. Right now I'd trade my licks for some video editing skills.Originally Posted by 45tripp
 I'm wondering how hard this would be to learn how to do. I'm really willing to tweak these clips. I can't expect or ask you to go into that in this thread but if you could point me in the right direction, I'd be grateful.Originally Posted by 45tripp
 Time to do some guide hunting.Originally Posted by 45tripp
 I don't and I am wrong. Thanks to both of you for bringing this to my attention!Originally Posted by 45tripp
 Damn, that looks great! It looks better than my 20mb file. I'll bet you kept the size down too. I would like to know how you did that but I'm not sure you'd want to go into that. Maybe point me towards some guides? I'm willing to spend as much time as it takes, so time and effort are not an issue for me. I tried dropping my framerate in avanti and it didn't do anything to the size of the file.Originally Posted by 45tripp
 I know that there's a lot to digest in my reply, but your guide is so great it really pumped me up. As far as "no thanks" being necessary, ricardo, anytime that somebody sacrafices some of their time to help me, thanks are certainly in order.
	i get that warning when i try to open avs files, i have avisynth 2.57 installed.Originally Posted by 45tripp
 I noticed a new version up will test and see if the same error pops up. Than
 Edit: That error still shows up, will report it. ThanksI love it when a plan comes together!
	No need to use ape for tweaking colour.Originally Posted by Captain Satellite
 exporting to mpg sounds unhealthy.
 Originally Posted by 45trippno, not really.Originally Posted by Captain Satellite
 read the ffmpeg manual.
 Soopafresh linked to a how to yesterday
 https://forum.videohelp.com/topic338564.html
 Ringing is trailing noise around a moving object.Originally Posted by Captain Satellite
 Yes avisynth. Essential tool. Start using it, there's no going back.
 http://avisynth.org/mediawiki/Main_Page#New_to_AviSynth_-_start_here
 which also links to this:
 http://www.animemusicvideos.org/guides/avtech/index.html
 a good read.
 There's the doom9 forum where developers of filters hang,
 and people churn out scripts that take days to run.
 If you're pumped, visit and start reading.
 It's good to find a specific task and start reading about it, and how other people deal with it.
 The speakers are heavy on detail that doesn't interest us.
 Mostly the shirt though that I find objectional
 Well it's really blurred, but compared to the alternative, yes it does look good.Originally Posted by Captain Satellite
 Your 700k has more detail but still retains some ugly artifacts.
 I used the settings you first posted. 345k video, 128k audio. Pushing to 500k, maybe a bit high for easy dreamy streaming.
 I can tell you exactly. My only concern is people blindly using what I crudely cooked for anything.Originally Posted by Captain Satellite
 Of course I'd always use dgindex, and load with mpeg2source(),Code:directshowsource("vhelptest.mpg") bicubicresize(320,240) tweak(cont=1.2, bright=-20, sat=1.3, hue=4) FFT3DGPU() blur(0.1) changefps(20)
 was just too bored to bother this time.
 (fft3dgpu() is an external filter)
 Never used ffmpeg for framerate change. Can't comment on it.Originally Posted by Captain Satellite
 As you see I used avisynth.
 Does one need the devil to seal such deals?Originally Posted by Captain Satellite
 I don't have editing skills though.
 gl
	That is A LOT to digest - thanks! I have a lot of reading to do!
	Hello there I am very glad I found this little guide. I wanted to improve the quality of my videos and managed to find this via Google.
 Anyway I just wanted to say I've followed your guide and at first found it a bit hard to understand but a fresh mind helped. Anyway I wanted to explain what I did as I have some questions in a minute.
 Basically I recorded a game via FRAPS which saves the video as an uncompressed .avi...Now with my set of videos I add a small title intro using Sony Vegas 7.0. I first experimented and found that saving to AVI meant that the video would not be converted to FLV by MPlayer. So I tried a WMV and that worked. Only problem I've found is it doesn't convert any video unless I add to the command line:
 -lavfopts i_certify_that_my_video_stream_does_not_use_b_fram es
 As it complains it cant initialise the Muxer.
 So adding that in it converts my 336x488 WMV video into an FLV file. Now I changed the audio to 48k and raised the bitrate from 400 to 1000. This was my first try as I now realise it affects the netload. Anyway using HEXCELLENT (German Version since that is all I could find) I edited the duration and thus the bitrate lowered to 345...
 I uploaded it to youtube and got the following results:
 http://www.youtube.com/watch?v=IJjPlak9rbc
 As you can see it is pretty good and I am happy with that. A 1 minute and I think 43 seconds video that was changed to 3:34 isn't bad. Anyway that was just a test and from the feedback it seems changing it to 1000 wasn't a good idea. So here are my questions:
 Basically since 1000 isn't a good idea since my 'real' videos will be much longer. Possible 10 mins + so what is a good suggested bitrate? I want a really good quality set of videos and I am not too concerned with audio quality...I suppose I should go back to 44k instead of 48.
 Also should I therefore cut the videos up to preserve quality? Like Part 1 Part 2 kinda thing? I assume that the longer a video is. The more you have to edit it with HEX the worse the quality gets? Forgive me I'm not a big video editor technical kinda guy.
 And lastly can you suggest anything else...Perhaps why I have to add that command line or why it refuses to convert my AVI to FLV...Just to give you an idea the AVI is around 1 gig uncompressed so that could be why? Oh also do you think Youtube will catch on and remove the videos that use this?
 Thanks for reading. I look forward to a reply.
	Your mencoder copy is outdated.Originally Posted by Habboi
 get mplayer from here
 http://oss.netfarm.it/mplayer-win32.php
 why not?Originally Posted by Habboi
 errors?
 try again with newer version.
 very long intro btw.
 wmv is fine.Originally Posted by Habboi
 it was an option when forced into 2 step encodes
 http://www.torry.net/pages.php?id=1176Originally Posted by Habboi
 Probably not. try again around the 500k markOriginally Posted by Habboi
 I've used 32kOriginally Posted by Habboi
 if you want quality, then yes you'll have to split them up.Originally Posted by Habboi
 if you want to upload 10+ mins then quality will obviously suffer. you'll have to shorten duration with hexcellent and will have to use a lower bitrate. (kill audio?)
 NoOriginally Posted by Habboi
 gl
	Alright thanks for the reply. Following your advice and using the updated programs I am pretty happy. Although at 500 Kbit it still looks horrible. I'm experimenting to see if everyone is happy with 750 Kbit...Funny thing is with 1000 Kbit the video worked fine for me and I even re-downloaded it after removing saved data and there was no lag. But with 750 I got 2 instances where it paused for a bit...
 Thanks anyway. I'll come back if I have any more questions.
	Habboi, a shooter cap like that doesn't have lots of motion, or lots of fine/random detail, or lots of color depth. So...
 You could preprocess your clip with Virtualdub (etc) making an intermediate lossless file that is 10/12/15/20fps (instead of 30), smoothed more, and 8/10/12/15/16bits of color depth (instead of 24). Subsequent processiing would make MUCH better use of the FLV's compression bitbudget--even with reduced overall bitrate--and without much noticeable difference in final/perceptible quality. This process can be extrapolated even further (w/ judicious editing, tweaking audio more, etc--basically "VBR"-style optimizing without actual VBR encoding).
	45tripp,
 I figured out the whole hex editing thing for duration, but I can't for the life of me understand how the frame rate values work. Could you expain how to derive proper values for them? I have a video for instance that was 59.94 FPS and I have no idea how you account for that.
 Also, is it theoretically possible to (assuming I don't want to mess up the video timeline metadata) to edit the reported bitrates for video and audio so they appear under a combined 350 Kb/s? I know changing the duration averages them out lower, but I hate having a messed up timeline like the TVC method.
	Nevermind I figured out the hex value for 30 FPS (reported):
 3E followed by fourteen zeros.
 I'd still like an answer to the other part of my question, though.
 Thanks.
	You tube corrects the time info in the file available for download/streaming while processing to change some header information  The time reported on download page at you tube is your "hexed" value. The time reported on download page at you tube is your "hexed" value.
 Using command line as suggested by 45tripp using WinFF (2 pass), you get acceptable videos with most sources without "hexing"
 @320x240-310kbps video-32 kbps 11025 kHz audio at 25 fps
 @352x264-with audio and video settings as above at 20 fps
 They are not free of blockiness, but when it occurs, it is mostly in the background and not so noticeable.
	what ever for?Originally Posted by Biggiesized
 The thought crossed my mind. I've not found anything.Originally Posted by Biggiesized
 Probably not, but if you get anywhere, let me know.
 neither here nor there.Originally Posted by mgh
 duration is fixed after metadata injection, but upload has already bypassed re-encode and
 at youtube playback, you still get misreported duration.
	Well, I've tried EVERYTHING to get this to work. No luck.
 At first, I couldn't figure out the command line encoder. But, I just copied your source right outta this window. And did the exact same settings.
 I also used the same uploader. YouTube keeps re-encoding the vid. Here's what MediaInfo reports:
 It says it's below 350k, but YouTube still re-encodes the vid.
 Oh well...
	"It says it's below 350k, but YouTube still re-encodes the vid.
 Oh well... "
 How do you know that? Don't you need to be 320x240 in order to not be re-encoded?
	Well the creator of this guide uploaded both 448x336 and 920x720 videos. Neither were re-encoded. As stated on the first post of this thread:
 http://www.youtube.com/watch?v=34tQi8HIpsA
 http://www.youtube.com/watch?v=OoVkD2k4byM
	Thanks soo much 45tripp,
 Your method is the greatest. I tryed with Riva, SUPER and Moyea's converters, but your way can't be beaten. It took a lot of time to figure out some parts, mostly because I've never had use mencoder before, and Avisynth was kind of overwhelming.
 After a lot of trail an error, the way I used to convert my video was by opening de Command Promt and writing:
 As you can see, I changed some things, starting by the bitrate, from 400 to 600, to the audio bitrate, if its that... cause Iam not sure.Code:"C:\mencoder.exe" "C:\video.avi" -o "c:\video.flv" -af resample=44100:0:0 -sws 9 -vf scale=448:-3,expand=448:336 -of lavf -ovc lavc -lavcopts vcodec=flv:vbitrate=600:trell:v4mv:mv0:mbd=2:cbp:aic:cmp=3:subcmp=3 -oac mp3lame -lameopts abr:br=64:mode=3
 I had to struggle a lot with the resolution of my video, as it had a very rare aspect ratio (5:4), with a resolution of 720x576. The original encoders of this video made some letterboxing on it, and removing it was a pain. After testing various "solutions", I opted for Vdubmod, wich opened my source video from wich I cutted the letterbox and added some filters to improve quality. I saved it as an RGB, cause frameserver to mencoder didn't worked for me. The I used the above code in command promt, and FINITO, here are my results:
 http://www.youtube.com/watch?v=gY80r8FbahU
 (My source video was kind of old, so the quality isn't outstanding, but Iam extremely happy with the results)
 THANKS AGAIN.
 Edit: Sorry, I forgot to ask you how can I change the framerate (fps) of the video?? If you could add that line of code to the one above, that would be GREAT. THANKS
	Thanks. I thought they would be re-encoded if they weren't.Originally Posted by Guiboche
	Well, I just tried Revan89's commandline. Didn't change anything accept the location of the filenames. Still no dice. And I've used HEXcellent to give the file a 10 minute mark. With a said rate of 107k. Way below 350k. Youtube still re-encoded it.
 Oh well. Time to give up......
	no.Originally Posted by Captain Satellite
 neither do you have framerate restrictions for that matter either
 You can't frameserve to mencoder with vdub.Originally Posted by Revan89
 you can put avisynth in between though.
 vdub -> avisynth-> mencoder
 I never change framerate in mencoder, but the switch is -ofps
 Looks fine.Originally Posted by Guiboche
 upload the flv, i'd like to try.
  Recommended upload video format for maximum sound quality on youtubeBy waigy in forum Video Streaming DownloadingReplies: 25Last Post: 12th Sep 2010, 18:09
  Youtube - bad upload qualityBy therock003 in forum Newbie / General discussionsReplies: 5Last Post: 26th Jul 2010, 03:49
  Poor quality following upload to YouTube-can anyone assist?By acceleratorhams in forum Video Streaming DownloadingReplies: 1Last Post: 1st Jun 2009, 16:16
  Poor Youtube Quality Upon UploadBy JohnSmith1981 in forum Video Streaming DownloadingReplies: 1Last Post: 20th Feb 2009, 13:54
  Youtube HQ upload slow on normal qualityBy seiun in forum Video Streaming DownloadingReplies: 2Last Post: 21st Sep 2008, 14:18
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
