Yes, but was it originally higher than 350 kbit/s? THAT's what is important here.Originally Posted by cinetech
Results 271 to 300 of 1969
hey ric are you still able to do the high quality hack?Originally Posted by ricardouk
yes, its still working, the last one i uploaded with a bitrate of 346k took about 30 seconds to appear online:
http://www.youtube.com/watch?v=7ev0HXPok8g
well if you're asking if i hexefy my uploads i don't, i dont do any "hacks", i just follow the bitrate limit, but ill try one later todayI love it when a plan comes together! -
I just uploaded a video and it got re-encoded. I used the 11 min hex hack and the file ended up 340 kbps, the file is 26.8 mb in size. I wonder if they've just blocked the 11 min limit?
I've been using mencoder for about 12 months and mainly just creating stereo music videos with just normal video quality in flv format. I hope these new hacks and the new HQ tutorials video on youtube haven't jeopardized the old stereo hack as well. It seems not with ricardouk newly uploaded video though, I'll try some tests later on.
45tripp, that tennis video I linked somehow has changed to standard quality. When I posted, that channels latest two videos were hi res quality and definitely 480x360 but now they're definitely not high quality and its the same url. It sounds odd or impossible but they were high quality for a few days, anyway no worries. -
its nice to see that ricardouk still managed to do the HQ trick. btw, can i ask something on how to edit the program with 480x360? cuz i tried the 320x240 but it looked crappy. the video im trying to upload has a run lenght of 3:17. so how do you do some editing for higher resolution with under 350 kbps still????
mmmarie can you post a link to your source? or host it at rapidshare or similar?
Like i said before i dont hexefy the videos i upload, fortunally they look good, but they all have 320x240 resolution with the bitrate under 345k.
avisynth, automen and a good source video is all i use, after the conversion i use mediainfo to check if the bitrate is under 345k, some of the videos look bad because i didnt knew of the trick (350+flv), others i didnt have a good source to begin with.
i dont do anything else to the video, just uploaded another one:
http://www.youtube.com/watch?v=ED-MYGiSdY8I love it when a plan comes together! -
looks great.Originally Posted by ricardouk
btw, may i ask why you changed the aspect ratio?
it seems the original is 1.85:1. -
just checked the original source and the aspect ratio is 2:35
i guess you meant 2.35:1 which is for 35mm anamorphicOriginally Posted by ricardouk
then again, will u encode the file using that ratio?
i love to see it. -
hello ricardouk. here is the video i wanted to put on youtube in HQ
http://www.megaupload.com/?d=199XAOU3 -
Reez rename the file to avi, for example movie1.divx becomes movie1.avi, divx files are avi files, the divx extension is used for chapters, menus and subs because avi doesnt do it, renaming it works.
Cinetech i see what you mean, the scripts i make i use avstodvd and it makes them taking in consideration the final resolution is 720x576 .
i changed the resolution in the script to 320x240 so im guessing the AddBorders value should change aswell like from 44 in the example to something lower, but i dont know how to do it, what values i should add, ive been looking in PDA's conversion forums for the answer but i havent found it.
its not perfect my solution but at least i now have the 16:9 look on the videos i wasnt getting before
Maybe 45stripp could help us outI love it when a plan comes together! -
mmmarie im on a 512 net connection, its going to take a while to download it but ill see what i can do tonight
Here´s your video, 320x240 resolution and 338k bitrate:
http://youtube.com/watch?v=gwb5hve1GvwI love it when a plan comes together! -
So yeah, we have a problem. The duration length hack doesn't work anymore. Any other ideas? xD
yes, i can only remember one site that has no limits on video types and size uploading without reconverting them
http://blip.tv/
you can use heyspread.com to move your youtube HD(if they havent been converted by now) videos to blip.tv, its not free but its cheap, a few cents by each upload
http://heyspread.com/
dont know any other service that does it for freeI love it when a plan comes together! -
I was thinking more on cropping the source to that aspect ratio 2.35:1,Originally Posted by ricardouk
and then try to letterbox to a 4:3, 320x240.
If you achieve that, it'll be easier to compress since it'll be more black,
from the bars.
Hopefully you can do it. -
oh thank you. so you just used the same format you demostrated before right? thankiesOriginally Posted by ricardouk
if anybody wants to experiment... try playing around with OTHER filetypes and try to figure out if youtube reads duration/bitrate/etc metadata from the file's header (or from footer/middle or wherever it reads it from lol).
this way we might discover another hole that will allow us to fake the meta data (aka duration) -
Someone make a new tutorial on how to get high quality video to upload on youtube , without it re encoding again, looks like youtube fixed it
ricardo. i opened up automen, but where do i load up the avs file at, can u show intstructions on how to load up your avs file to work with automen? so it can start converting
just "drag and drop" the file on Automen
all good things come to an end.
i'll update the guide to indicate the hq hack no longer works.
uploading flv's is still useful as ricardo shows,
but eye popping quality has gone.
strangely 44 is close, for the 2.35:1, but the method is all wrong.Originally Posted by ricardouk
for 4:3 just resize:
lanczos4resize(320,240)
for 16:9:
lanczos4resize(320,180).addborders(0,30,0,30)
for 2.35:1:
lanczos4resize(320,144).addborders(0, 48, 0, 48 )
sabotage!Originally Posted by duro
gl,
tripp -
got it working now:
avs script for imitating 2.35.1 aspect ration on a 4:3 video:
video on youtube:Code:DirectShowSource("C:\test\2_35_1_source.avi") Lanczos4Resize(320,144) AddBorders(0,48,0,48)
http://www.youtube.com/watch?v=5f_uyXs1X30
avs script for imitating 1.78.1 aspect ration on a 4:3 video:
video on youtube:Code:DirectShowSource("C:\test\1_78_1_source.avi") Lanczos4Resize(320,180) AddBorders(0,30,0,30)
http://www.youtube.com/watch?v=9bNoIA4b8pU
looking good!Originally Posted by ricardouk
although i don't get why you're using 25fps?
if your source is pal, you should use 12fps.
it'll still play well and smooth, while you gain
more kbps for encoding.
for my 30 fps source videos, i use 15fps for FLV <350kbps -
yes, im trying to do this in "steps", first i want to get the aspect ratio problem sorted and then optimize the videos by changing the framerate.
doing it in small steps instead of doing it all at once
Edit: Automen doesnt have a fps conversion option, ive asked Buzzqw if he could implement the feature in Automen, he listens the users of his programs, hopefully he will implement it, fingers crossed :
Recommended upload video format for maximum sound quality on youtube
By waigy in forum Video Streaming DownloadingReplies: 25Last Post: 12th Sep 2010, 18:09 -
Youtube - bad upload quality
By therock003 in forum Newbie / General discussionsReplies: 5Last Post: 26th Jul 2010, 03:49 -
Poor quality following upload to YouTube-can anyone assist?
By acceleratorhams in forum Video Streaming DownloadingReplies: 1Last Post: 1st Jun 2009, 16:16 -
Poor Youtube Quality Upon Upload
By JohnSmith1981 in forum Video Streaming DownloadingReplies: 1Last Post: 20th Feb 2009, 13:54 -
Youtube HQ upload slow on normal quality
By seiun in forum Video Streaming DownloadingReplies: 2Last Post: 21st Sep 2008, 14:18
