I have a USB hard drive that I'm using with the Philips DVP5982. It's working great, everything plays back well (except WMV and OGM, of course) - but I can't see some of my files and folders. I have MP3 folder several levels deep that I can see, but others I can't see past one or two levels deep. Has anyone found a solution to this? I don't think it's a naming issue, but I may try playing with that just to rule it out.
(BTW, I have searched the forums but have found no answers, though others have posed the question within other threads.)
Thanks in advance,
PunkHippie
Welcome PunkHippie
A: Check name lengths don't exceed 64 characters .
B: Can you play files in lower folder groups from main list , as in
video : mpeg : avi : mkv
Audio : wma : mp3 : wav : ac3 (lets say folder mp3 is in question)
Pics : jpeg : bmp : png : tiff (are you able to browse through the lower groups without error)
C: how big is this partition to begin with ?
Rename folders above problematic group to z , y , x ... till folders that appear above in main group now appear lower in main group , and try again ... could be Max partition read abilities reached .
You should stick with dos structure for naming = 8:3 format . -
It's possible the player can't read 250GB, but that is irrelevant at this point. Your player is having trouble accessing the FAT. As was stated in the "renaming folders..." statement above, try renaming folders with short names to find out if the folders in lower levels are then readable. The character limit pertains to each full path, not just the folder and file name. In other words, the number of characters within each subfolder get added to the parent folder name. (example: The parent folder is ALL OF MY FAVORITE MOVIES (25 characters). Folders within that folder now only have a 39 character limit (64-25=39).
Google is your Friend
Philips DVP5982/37 USB file question
By kme06d in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Jun 2011, 18:09 -
Philips DVP5982 Compatible USB Flash Drives
By Nikephoros in forum DVD & Blu-ray PlayersReplies: 22Last Post: 20th Mar 2009, 01:34 -
Philips DVP5960 USB hard drive help
By JustinBaker in forum DVD & Blu-ray PlayersReplies: 2Last Post: 11th Dec 2008, 16:03 -
Philips DVP5982 USB FYI
By 403gl in forum DVD & Blu-ray PlayersReplies: 5Last Post: 1st May 2008, 08:53 -
Philips DVP5982 USB & StaxRip
By Trac in forum DVD & Blu-ray PlayersReplies: 10Last Post: 17th Sep 2007, 12:20
