PC: Dell 9150
OS: Windows XP Pro
Software: VLC media player 0.8.6c
I used VLC media player 0.8.6c for months. It worked perfectly. I can click different (or, even same) movie files (.iso) and VLC will open different windows and play the movies separately, at the same time.
But recently, if I click on the second movie file, the first movie on the first VLC window will stop, and the same window will play the second movie instead. No more multi VLC windows available.
I uninstall VLC, clean up the preference and registration, then re-install VLC. But the condition does not change.
Can anybody help me to solve this problem??
	I think this will take care of the problem:
 Go to Settings -> Preferences -> Advanced. Tick Advanced Options in the lower right hand corner. Disable the One Instance When Started Fome File option.
	Thank you very much.
 After 'Disable the One Instance', everything runs normally.
  Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 08:28
  Videolan VLC Play Random Parts of Playlist MoviesBy ilcarletto in forum ProgrammingReplies: 2Last Post: 6th Apr 2011, 03:51
  How to stream live tv or video with VLC/videolanBy Baldrick in forum User guidesReplies: 19Last Post: 17th Dec 2010, 02:49
  Latest Videolan (VLC) Plays AVCHD FilesBy Soopafresh in forum Latest Video NewsReplies: 7Last Post: 3rd Nov 2008, 23:40
  problem with VLC media playerBy marlo in forum Newbie / General discussionsReplies: 2Last Post: 19th Nov 2007, 06:44
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
