i got the following mistake after finishing the burning process:
Version: SVCD2DVD 2.5
Build: 2.5.3100.0
Type: System.NullReferenceException
Source: SVCD2DVD
Message: Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt.
InnerException:
StackTrace: bei x3284ccece41ee22b.xd3764d4f1e921081.x24919c2ff8f0c 9b2()
bei x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
bei System.Threading.ThreadHelper.ThreadStart_Context( Object state)
bei System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state)
bei System.Threading.ThreadHelper.ThreadStart()
my dvd players says: no disk
can anybody help me?
What program are you using to burn?
Does the disc work in your PC (i.e. did it burn)?
Does the VIDEO_TS folder exist in your output folder?Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Can you post your log file for this run please?
MPC-HC upgrade a mistake?
By Monarch1st in forum Software PlayingReplies: 10Last Post: 26th Feb 2012, 14:24 -
please help me, format my camcorder hdr sr-12 by a mistake
By oof7 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 9th Feb 2012, 12:11 -
I just bought an expensive laptop - was it a $2500 mistake?
By Eat Right in forum ComputerReplies: 35Last Post: 18th Nov 2009, 12:33 -
Mistake to buy a standard definition TV?
By LT9000 in forum Newbie / General discussionsReplies: 39Last Post: 28th Aug 2007, 09:39
