Ok, so I have everything set up. Everything is plugged in, software isn't crashing and I am ready to use the product, which is Adaptec Gamebridge ( Ironic that Dazzle didn't work when I paid like £50 more for it :P ). I turn it on and I get this, http://www.youtube.com/watch?v=Jo4oCaFeSpw. By the way, the sound at the start is only because the audio cables weren't plugged in due to some tweaking. This works ONLY on 50Hz. As soon as I switch to 60Hz, here is what happens, http://www.youtube.com/watch?v=6d-tTz6Dpt4&mode=user&search=.
I have no idea why it only works on 50Hz, and this poses a problem as all major games, well at least Gears which is the most important, only works on 60Hz.
So, any help?
P.S I wasn't switching to 60Hz in the working video as I wanted it all working, the long black part is just when I switched the Xbox to HDTV to see what would happen.
Results 1 to 1 of 1
how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?
By rushinplaya in forum Capturing and VCRReplies: 18Last Post: 3rd Apr 2010, 06:19 -
Capture Card xbox 360
By Mastapka53 in forum Capturing and VCRReplies: 2Last Post: 27th Mar 2010, 13:50 -
Xbox 360 Capture Card
By Dr Awesome in forum Capturing and VCRReplies: 2Last Post: 19th Feb 2010, 05:06 -
Best capture card for xbox 360?
By Edward1982 in forum Newbie / General discussionsReplies: 2Last Post: 28th Jul 2009, 15:53 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 19:42
