I just got my new TBC (AVT-8710), and I'm getting ready to do my first capture with it. I also finally got the cable to allow me to connect a S-video output to my old Commodore 1702 monitor. Here's the wiring:
JVC HR-S7800U VCR's S-Video out ->
TBC's S-video in ->
TBC's S-video out
Pyro's S-video in ->
Pyro's S-video out ->
1702 monitor
JVC HR-S7800U VCR's audio out ->
Pyro's audio in ->
Pyro's audio out ->
stereo to mono rca adapter ->
1702 monitor
Pyro's firewire out ->
PC's firewire in
The big question -- when capturing, is the Pyro's s-video output just the passed-through s-video input? Or is the Pyro capturing the video, compressing it to DV, then simultaneously sending it out via firewire and decompressing it to its s-video output as an accurate preview of what was just encoded?
	Well, TBC disappointment #1... I still get 36 or 37 dropped frames whenever the VCR's video output vomits. I was kind of hoping the TBC would just maintain a stiff upper lip and output a perfectly-timed frame of noise & the Pyro would never even realize anything unusual had just happened. It does, however, seem to be helping to eliminate some of the smaller hiccups entirely. Pre-TBC, there were times when I'd just see the video jump or glitch for a moment before seeing the 'dropped frames' counter increment by 36 or 37. Now, it only seems to be doing it in spots where the tape was genuinely mangled & the video output REALLY vomits. But so far, I'm ~10 minutes into the capture, so this might change
 Also... will using the JVC VCR's line TBC IN ADDITION to the external TBC help or hurt? From the experiments I did, turning it off didn't seem to help, but it DID cause the VCR to completely lose its ability to output anything besides a blue screen with the word "play" in some of the worst spots. Likewise, the video is jumping a bit vertically. Would disabling the internal TBC and enabling the VCR's stabilizer help things? Or am I better off letting the captured frames jump and quiver a bit with the internal TBC in place, and using something downstream (Avisynth?) to clean up the vertical instability?
	Well, another interesting/weird development. It appears that a video glitch longer than ~1 second (hmmm... 36 or 37 frames?) derails WinDV. I see the burst of noise happen on the S-video monitor and in the preview window, but the preview window never recovers, and if I let it keep capturing, it captures garbage. However, if I pause and un-pause capture at that point, it resumes capturing just fine. Weird.
 Does any 2-way communication take place between Windows and the Pyro when a capture begins? Or is the Pyro ALWAYS trying to capture, and broadcasting what it captures, down the Firewire bus? I'm trying to figure out whether it's the Pyro that's crashing, and the act of pausing and un-pausing WinDV resets it, or whether WinDV itself is what's having the problem...
  View output from video capture cardBy kkpatel87 in forum Video Streaming DownloadingReplies: 2Last Post: 23rd Jul 2009, 20:30
  PAL DV - which of these 4:2:0 subsampling representation is correct ?By Movie-Maker in forum Newbie / General discussionsReplies: 17Last Post: 12th Dec 2008, 16:00
  SolveigMM Video Splitter 2.0 with MPEG-2 frame accurate editing is outBy DmitryV in forum Latest Video NewsReplies: 4Last Post: 23rd Aug 2008, 06:54
  How do I split and capture the video on the DVI output on MacBook Pro?By kmxe in forum Newbie / General discussionsReplies: 6Last Post: 18th Jul 2008, 21:49
  Component video capture with PYRO A /V Link?By theinv in forum Capturing and VCRReplies: 2Last Post: 19th Sep 2007, 18:47
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
