I have a movie which is in two avi files & i want to join them into 1 dvd without a menu. But when i join them will the second part play smoothly after the other or will the title stop and then the film stops half way through?
Thanks in advance
Results 1 to 10 of 10
SaM*T
You shouldn't join. Encode each AVI to mpg separately, and bring them together at the authoring stage.
Or use convertx2dvd that works like this but is a oneclick wonder.
/Mats -
IIRC convertxtodvd will create 2 titles for 2 AVIs, so in this case Bjs (joining) is right on the money IMHO.
If in doubt, Google it. -
However you can set ConvertXtoDVD to play the titles sequentially, and the break will be no more intrusive than a standard layer break.
Read my blog here.
I too am having the same problem with convertx to dvd.
Under settings...menus... I select 'Sequential Playback'
However, when I playback the final disc, it still stops after the first track.
What am I doing wrong ?
H E L P !
Bjs has the best answer - join both files using vdub or similar, so long as both parts are identical format/frame size/etc
This works 100% of the time, especially when you want to add chapters to your final DVD
When playing the final chapter of part1 you cannot jump to chapter1 on part2 - you must allow part1 to finish.
I gave up using "sequential" because the pauses between parts became too much to bear, and joining only adds about 5 minutes to the total process time anyway.Don't worry.......we'll be alright... -
Thanks Everyone for your help. Now i have sorted out the problem and i join the files with virtualdub and convert with convertx and its all perfect. Thanks
SaM*T
How to convert FLV videos and resize them to convert them to AVI
By zikegi in forum Video ConversionReplies: 2Last Post: 18th Sep 2011, 00:06 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 06:44 -
how to convert dvd with dts audio to a dvd playable on a dvd player
By flannob in forum Newbie / General discussionsReplies: 5Last Post: 19th Sep 2010, 07:46 -
To convert or not to convert a pal dvd
By nls8520 in forum Video ConversionReplies: 1Last Post: 22nd Jun 2010, 02:35 -
Convert PAL 16x9 DVD to NTSC DVD w/ Procoder - Less Image-More Borders Why?
By tubularusa in forum DVD RippingReplies: 15Last Post: 5th Aug 2007, 02:26
