i am running win xp and virtual dub 1.3c and i have installed the smr patch. my problem is when i try and save a wav file it saves it as an unrecognizable file extention and therefore i cant load the asf it in tmpgenc. when i was running virtualdub 1.4.8 it would save it as a recognizable file extension and i could load it in tmpgenc. Can someone give me some advice on what to try?
thanks in advance
..uuhm.... why would you use 1.3....??? i say: stick with the new version
as long as my boss thinks i make a lot of money, i will pretend to work hard ;) -
because with the new version you cant convert asf files in virtualdub. if you try it tells you that microsoft owns the patent and that feautre has been disabled.
anybody have any suggestions?
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 13:26 -
Help PLZ! subtitle problem.
By Ajimal in forum Newbie / General discussionsReplies: 2Last Post: 15th Feb 2010, 22:25 -
plz help
By sajjad223 in forum Video Streaming DownloadingReplies: 1Last Post: 4th May 2008, 10:12 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08 -
my PC stats plz help can i edit on this
By Kigi in forum ComputerReplies: 8Last Post: 30th May 2007, 02:30
