Hi,
I am using DVDStyler for the first time, trying to put three videos on the same DVD, with a menu, etc. But I cannot save my work as an ISO file, here is the whole report that I get (it seems to work fine until the very end, adding ECC data):
Préparation
Nettoyage du répertoire temporaire
Création de menus
Création du menu 1 de 1
Préparation
Conversion JPEG vers MPEG
INFO: [jpeg2yuv] Parsing & checking input files.
INFO: [jpeg2yuv] YUV colorspace detected.
INFO: [jpeg2yuv] Starting decompression
INFO: [jpeg2yuv] Image dimensions are 720x576
INFO: [jpeg2yuv] Movie frame rate is: 25.000000 frames/second
INFO: [jpeg2yuv] Interlaced frames, top field first.
INFO: [jpeg2yuv] Frame size: 720 x 576
INFO: [jpeg2yuv] Number of Loops 1
INFO: [jpeg2yuv] Now generating YUV4MPEG stream.
INFO: [jpeg2yuv] Processing non-interlaced/interleaved C:\Documents and Settings\zaz\dvd\dvd\dvd\menu1-0.mpg_bg.jpg, size 95035
INFO: [jpeg2yuv] Rescaling color values.
++ WARN: [mpeg2enc] Unknown stream tag encountered: 'C420jpeg'
INFO: [mpeg2enc] Selecting DVD output profile
INFO: [mpeg2enc] Assuming norm PAL
INFO: [mpeg2enc] Encoding MPEG-2 video to C:\Documents and Settings\zaz\dvd\dvd\dvd\menu1-0.mpg_bg.m2v
INFO: [mpeg2enc] Horizontal size: 720 pel
INFO: [mpeg2enc] Vertical size: 576 pel
INFO: [mpeg2enc] Aspect ratio code: 1 = 1:1 pixels
INFO: [mpeg2enc] Frame rate code: 3 = 25.0 (PAL/SECAM VIDEO / converted FILM)
INFO: [mpeg2enc] Bitrate: 9000 KBit/s
INFO: [mpeg2enc] Quality factor: 8 (1=best, 31=worst)
INFO: [mpeg2enc] Field order for input: top-field-first
INFO: [mpeg2enc] Sequence unlimited length
INFO: [mpeg2enc] Search radius: 16
INFO: [mpeg2enc] GOP SIZE RANGE 9 TO 15
INFO: [mpeg2enc] Setting colour/gamma parameters to "PAL B/G"
INFO: [mpeg2enc] Progressive format frames = 0
INFO: [mpeg2enc] Buffering 39 frames
INFO: [mpeg2enc] SETTING 3DNOW and EXTENDED MMX for QUANTIZER!
INFO: [mpeg2enc] SETTING EXTENDED MMX for MOTION!
INFO: [mpeg2enc] SETTING MMX for TRANSFORM!
INFO: [mpeg2enc] SETTING EXTENDED MMX for PREDICTION!
INFO: [mpeg2enc] GOP LENGTH = 1
INFO: [mpeg2enc] Frame start 0 I 0 0
INFO: [mpeg2enc] Frame end 0 373.22 373.22 8.0 8.00
INFO: [mpeg2enc] GOP LENGTH = 0
Multiplexage de l'audio et de la vidéo
INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
INFO: [???] File C:\Documents and Settings\zaz\dvd\dvd\dvd\menu1-0.mpg_bg.m2v looks like an MPEG Video stream.
INFO: [???] File C:\Program Files\DVDStyler\data\silence.mp2 looks like an MPEG Audio stream.
INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
INFO: [???] Found 1 audio streams and 1 video streams
INFO: [???] Selecting dvdauthor DVD output profile
INFO: [???] Multiplexing video program stream!
INFO: [???] Scanning for header info: Video stream e0 (C:\Documents and Settings\zaz\dvd\dvd\dvd\menu1-0.mpg_bg.m2v)
INFO: [???] VIDEO STREAM: e0
INFO: [???] Frame width : 720
INFO: [???] Frame height : 576
INFO: [???] Aspect ratio : 1:1 pixels
INFO: [???] Picture rate : 25.000 frames/sec
INFO: [???] Bit rate : 9000000 bits/sec
INFO: [???] Vbv buffer size : 229376 bytes
INFO: [???] CSPF : 0
INFO: [???] Scanning for header info: Audio stream c0 (C:\Program Files\DVDStyler\data\silence.mp2)
INFO: [???] MPEG AUDIO STREAM: c0
INFO: [???] Audio version : 1.0
INFO: [???] Layer : 2
INFO: [???] CRC checksums : no
INFO: [???] Bit rate : 16384 bytes/sec (128 kbit/sec)
INFO: [???] Frequency : 48000 Hz
INFO: [???] Mode : 0 stereo
INFO: [???] Mode extension : 0
INFO: [???] Copyright bit : 0 no copyright
INFO: [???] Original/Copy : 0 copy
INFO: [???] Emphasis : 0 none
INFO: [???] SYSTEMS/PROGRAM stream:
INFO: [???] rough-guess multiplexed stream data rate : 9319496
INFO: [???] target data-rate specified : 10080000
INFO: [???] Setting specified specified data rate: 10080000
INFO: [???] Scanned to end AU 0
INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 0
INFO: [???] New sequence commences...
INFO: [???] Video e0: buf= 237568 frame=000000 sector=00000000
INFO: [???] Audio c0: buf= 4096 frame=000000 sector=00000000
INFO: [???] STREAM e0 completed @ frame 0.
INFO: [???] STREAM c0 completed @ frame 249.
INFO: [???] Multiplex completion at SCR=537453.
INFO: [???] Video e0: buf= 237568 frame=000000 sector=00000016
INFO: [???] Audio c0: buf= 1024 frame=000249 sector=00000048
INFO: [???] VIDEO_STATISTICS: e0
INFO: [???] Video Stream length: 30637 bytes
INFO: [???] Sequence headers: 1
INFO: [???] Sequence ends : 1
INFO: [???] No. Pictures : 0
INFO: [???] No. Groups : 1
INFO: [???] No. I Frames : 1 avg. size 30637 bytes
INFO: [???] No. P Frames : 0 avg. size 0 bytes
INFO: [???] No. B Frames : 0 avg. size 0 bytes
INFO: [???] Average bit-rate : 6127200 bits/sec
INFO: [???] Peak bit-rate : 0 bits/sec
INFO: [???] BUFFERING stream too short for useful statistics
INFO: [???] AUDIO_STATISTICS: c0
INFO: [???] Audio stream length 96000 bytes.
INFO: [???] Syncwords : 250
INFO: [???] Frames : 250 padded
INFO: [???] Frames : 0 unpadded
INFO: [???] MUX STATUS: no under-runs detected.
Multiplexage mpeg des sous-titres (boutons)
DVDAuthor:pumux, version 0.6.14-GfD-1.
Build options: gnugetopt iconv freetype
Send bugs to <gfd@boraxsoft.de>
INFO: Locale=C
INFO: Converting filenames to US-ASCII
STAT: 0:00:00.000
INFO: PNG had 2 colors
INFO: Pickbuttongroups, success with 1 groups, useimg=1
INFO: Found EOF in .sub file.
INFO: Max_sub_size=1284
INFO: 1 subtitles added, 0 subtitles skipped, stream: 32, offset: 0.18
Création des fichiers VOB
Fix MPEG-file: E:\Elsa\Etincelle\Au fil de l'arbre\CD Arbre\arbre pour dvd.mpg
DemultiplexingXXX : [audio 01 video 01] [ 0.89%]
DemultiplexingXXX : [audio 01 video 01] [ 5.44%]
DemultiplexingXXX : [audio 01 video 01] [ 10.90%]
DemultiplexingXXX : [audio 01 video 01] [ 15.46%]
DemultiplexingXXX : [audio 01 video 01] [ 20.01%]
DemultiplexingXXX : [audio 01 video 01] [ 25.47%]
DemultiplexingXXX : [audio 01 video 01] [ 30.02%]
DemultiplexingXXX : [audio 01 video 01] [ 35.48%]
DemultiplexingXXX : [audio 01 video 01] [ 40.03%]
DemultiplexingXXX : [audio 01 video 01] [ 45.49%]
DemultiplexingXXX : [audio 01 video 01] [ 50.05%]
DemultiplexingXXX : [audio 01 video 01] [ 55.51%]
DemultiplexingXXX : [audio 01 video 01] [ 60.06%]
DemultiplexingXXX : [audio 01 video 01] [ 65.52%]
DemultiplexingXXX : [audio 01 video 01] [ 70.07%]
DemultiplexingXXX : [audio 01 video 01] [ 75.53%]
DemultiplexingXXX : [audio 01 video 01] [ 80.08%]
DemultiplexingXXX : [audio 01 video 01] [ 85.55%]
DemultiplexingXXX : [audio 01 video 01] [ 90.10%]
DemultiplexingXXX : [audio 01 video 01] [ 95.54%]
Demultiplexing : [audio 01 video 01] [100.00%]
INFO: [???] File C:\Documents and Settings\zaz\dvd\dvd\dvd\title0-0-0-0.m1v looks like an MPEG Video stream.
INFO: [???] File C:\Documents and Settings\zaz\dvd\dvd\dvd\title0-0-0-0.mp2 looks like an MPEG Audio stream.
INFO: [???] Scanning for header info: Video stream e0 (C:\Documents and Settings\zaz\dvd\dvd\dvd\title0-0-0-0.m1v)
INFO: [???] Frame width : 352
INFO: [???] Frame height : 288
INFO: [???] Aspect ratio : forbidden
INFO: [???] Picture rate : 29.970 frames/sec
INFO: [???] Bit rate : variable
INFO: [???] Vbv buffer size : 47104 bytes
INFO: [???] Scanning for header info: Audio stream c0 (C:\Documents and Settings\zaz\dvd\dvd\dvd\title0-0-0-0.mp2)
INFO: [???] Bit rate : 28672 bytes/sec (224 kbit/sec)
INFO: [???] Frequency : 44100 Hz
INFO: [???] rough-guess multiplexed stream data rate : 0235296
INFO: [???] Scanned to end AU 3220
INFO: [???] STREAM e0 completed @ frame 3220.
INFO: [???] STREAM c0 completed @ frame 5049.
INFO: [???] Multiplex completion at SCR=11877083.
INFO: [???] Video e0: buf= 237568 frame=003220 sector=00003732
INFO: [???] Audio c0: buf= 1171 frame=005049 sector=00001829
INFO: [???] Video Stream length: 7396882 bytes
INFO: [???] Sequence headers: 220
INFO: [???] No. Pictures : 3220
INFO: [???] No. Groups : 220
INFO: [???] No. I Frames : 220 avg. size 6106 bytes
INFO: [???] No. P Frames : 880 avg. size 2665 bytes
INFO: [???] No. B Frames : 2121 avg. size 1748 bytes
INFO: [???] Average bit-rate : 550400 bits/sec
INFO: [???] Peak bit-rate : 2272800 bits/sec
INFO: [???] BUFFERING min 38 Buf max 229461
INFO: [???] Audio stream length 3693714 bytes.
INFO: [???] Syncwords : 5050
INFO: [???] Frames : 2886 padded
INFO: [???] Frames : 2164 unpadded
INFO: [???] BUFFERING min 16 Buf max 745
Fix MPEG-file: E:\vidéos\cata.mpg
DemultiplexingXXX : [audio 01 video 01] [ 0.10%]
DemultiplexingXXX : [audio 01 video 01] [ 5.04%]
DemultiplexingXXX : [audio 01 video 01] [ 10.09%]
DemultiplexingXXX : [audio 01 video 01] [ 15.03%]
DemultiplexingXXX : [audio 01 video 01] [ 20.08%]
DemultiplexingXXX : [audio 01 video 01] [ 25.02%]
DemultiplexingXXX : [audio 01 video 01] [ 30.07%]
DemultiplexingXXX : [audio 01 video 01] [ 35.01%]
DemultiplexingXXX : [audio 01 video 01] [ 40.06%]
DemultiplexingXXX : [audio 01 video 01] [ 45.00%]
DemultiplexingXXX : [audio 01 video 01] [ 50.04%]
DemultiplexingXXX : [audio 01 video 01] [ 55.09%]
DemultiplexingXXX : [audio 01 video 01] [ 60.03%]
DemultiplexingXXX : [audio 01 video 01] [ 65.08%]
DemultiplexingXXX : [audio 01 video 01] [ 70.02%]
DemultiplexingXXX : [audio 01 video 01] [ 75.07%]
DemultiplexingXXX : [audio 01 video 01] [ 80.01%]
DemultiplexingXXX : [audio 01 video 01] [ 85.06%]
DemultiplexingXXX : [audio 01 video 01] [ 90.00%]
DemultiplexingXXX : [audio 01 video 01] [ 95.04%]
INFO: [???] File C:\Documents and Settings\zaz\dvd\dvd\dvd\title0-1-0-0.m1v looks like an MPEG Video stream.
INFO: [???] File C:\Documents and Settings\zaz\dvd\dvd\dvd\title0-1-0-0.mp2 looks like an MPEG Audio stream.
INFO: [???] Scanning for header info: Video stream e0 (C:\Documents and Settings\zaz\dvd\dvd\dvd\title0-1-0-0.m1v)
INFO: [???] Scanning for header info: Audio stream c0 (C:\Documents and Settings\zaz\dvd\dvd\dvd\title0-1-0-0.mp2)
INFO: [???] Scanned to end AU 9798
INFO: [???] STREAM e0 completed @ frame 9798.
INFO: [???] STREAM c0 completed @ frame 16331.
INFO: [???] Multiplex completion at SCR=35285284.
INFO: [???] Video e0: buf= 237356 frame=009798 sector=00043304
INFO: [???] Audio c0: buf= 2080 frame=016331 sector=00005434
INFO: [???] Video Stream length: 87030701 bytes
INFO: [???] Sequence headers: 654
INFO: [???] No. Pictures : 9798
INFO: [???] No. Groups : 654
INFO: [???] No. I Frames : 654 avg. size 18903 bytes
INFO: [???] No. P Frames : 2613 avg. size 8071 bytes
INFO: [???] No. B Frames : 6532 avg. size 8202 bytes
INFO: [???] Average bit-rate : 1776000 bits/sec
INFO: [???] Peak bit-rate : 6768400 bits/sec
INFO: [???] BUFFERING min 15 Buf max 224706
INFO: [???] Audio stream length 10975104 bytes.
INFO: [???] Syncwords : 16332
INFO: [???] Frames : 16332 padded
INFO: [???] BUFFERING min 15 Buf max 683
Création du DVD
DVDAuthor::dvdauthor, version 0.6.14-GfD-1.
INFO: Locale=C
INFO: dvdauthor creating VTS
WARN: First cell is not marked as a chapter in PGC 0, setting chapter flag
WARN: First cell is not marked as a chapter in PGC 1, setting chapter flag
STAT: Picking VTS 01
STAT: Processing C:\Documents and Settings\zaz\dvd\dvd\dvd\menu1-0.mpg...
WARN: unknown mpeg2 aspect ratio 1
INFO: Video pts = 0.184 .. 0.224
INFO: Audio[8] pts = 0.184 .. 6.184
INFO: Audio[32] pts = 0.184 .. 0.184
STAT: VOBU 1 at 0MB, 1 PGCS
INFO: Generating VTSM with the following video attributes:
INFO: MPEG version: mpeg2
INFO: TV standard: pal
INFO: Aspect ratio: 4:3
INFO: Resolution: 720x576
INFO: Audio ch 0 format: mp2/2ch, 48khz 16bps
STAT: Processing C:\Documents and Settings\zaz\dvd\dvd\dvd\title0-0-0.vob...
WARN: Discontinuity of 7053 in audio channel 8; please remultiplex input.
WARN: Previous sector: 0.178 - 0.178
WARN: Current sector: 0.256 - 0.256
WARN: Previous sector: 0.256 - 0.256
WARN: Current sector: 0.334 - 0.334
WARN: Previous sector: 0.334 - 0.334
WARN: Previous sector: 0.543 - 0.543
WARN: Current sector: 0.831 - 0.831
WARN: Discontinuity of 4702 in audio channel 8; please remultiplex input.
WARN: Previous sector: 1.275 - 1.275
WARN: Current sector: 1.562 - 1.562
- 1.771
WARN: Previous sector: 2.006 - 2.006
WARN: Current sector: 2.293 - 2.293
WARN: Previous sector: 2.502 - 2.502
WARN: Previous sector: 4.880 - 4.880
5.898 - 5.898
WARN: Current sector: 7.335 - 7.335
STAT: VOBU 16 at 1MB, 2 PGCS
7.831 - 7.831
9.921
WARN: Previous sector: 12.089 - 12.089
13.813 - 13.813
WARN: Current sector: 14.545 - 14.545
15.851 - 15.851
STAT: VOBU 32 at 2MB, 2 PGCS
17.784 - 17.784
WARN: Previous sector: 19.299 - 19.299
21.676 - 21.676
WARN: Current sector: 21.755 - 21.755
23.714 - 23.714
WARN: Previous sector: 24.132 - 24.132
25.647
STAT: VOBU 48 at 3MB, 2 PGCS
29.696 - 29.696
35.600 - 35.600
STAT: VOBU 64 at 4MB, 2 PGCS
43.619
STAT: VOBU 80 at 5MB, 2 PGCS
WARN: Previous sector: 48.164 - 48.164
49.549
51.482
55.453 - 55.453
57.464 - 57.464
59.423 - 59.423
61.435 - 61.435
WARN: Current sector: 72.249 - 72.249
STAT: VOBU 96 at 7MB, 2 PGCS
79.198 - 79.198
81.209 - 81.209
STAT: VOBU 112 at 8MB, 2 PGCS
89.151
91.162 - 91.162
- 93.121
STAT: VOBU 128 at 9MB, 2 PGCS
95.054 - 95.054
97.066 - 97.066
99.025
- 102.917
112.739 - 112.739
116.631
118.512
WARN: Previous sector: 120.315 - 120.315
126.375 - 126.375
130.189 - 130.189
INFO: Video pts = 0.178 .. 108.819
INFO: Audio[8] pts = 0.178 .. 132.070
STAT: Processing C:\Documents and Settings\zaz\dvd\dvd\dvd\title0-1-0.vob...
STAT: VOBU 158 at 13MB, 2 PGCS
STAT: VOBU 174 at 16MB, 2 PGCS
STAT: VOBU 190 at 18MB, 2 PGCS
STAT: VOBU 206 at 21MB, 2 PGCS
STAT: VOBU 222 at 23MB, 2 PGCS
STAT: VOBU 238 at 24MB, 2 PGCS
STAT: VOBU 254 at 26MB, 2 PGCS
STAT: VOBU 270 at 28MB, 2 PGCS
STAT: VOBU 286 at 31MB, 2 PGCS
STAT: VOBU 302 at 33MB, 2 PGCS
STAT: VOBU 318 at 36MB, 2 PGCS
STAT: VOBU 334 at 38MB, 2 PGCS
STAT: VOBU 350 at 39MB, 2 PGCS
STAT: VOBU 366 at 42MB, 2 PGCS
STAT: VOBU 382 at 43MB, 2 PGCS
STAT: VOBU 398 at 46MB, 2 PGCS
STAT: VOBU 414 at 49MB, 2 PGCS
STAT: VOBU 430 at 51MB, 2 PGCS
STAT: VOBU 446 at 53MB, 2 PGCS
STAT: VOBU 462 at 56MB, 2 PGCS
STAT: VOBU 478 at 58MB, 2 PGCS
STAT: VOBU 494 at 60MB, 2 PGCS
STAT: VOBU 510 at 63MB, 2 PGCS
STAT: VOBU 526 at 65MB, 2 PGCS
STAT: VOBU 542 at 68MB, 2 PGCS
STAT: VOBU 558 at 70MB, 2 PGCS
STAT: VOBU 574 at 72MB, 2 PGCS
STAT: VOBU 590 at 73MB, 2 PGCS
STAT: VOBU 606 at 75MB, 2 PGCS
STAT: VOBU 622 at 77MB, 2 PGCS
STAT: VOBU 638 at 79MB, 2 PGCS
STAT: VOBU 654 at 81MB, 2 PGCS
STAT: VOBU 670 at 84MB, 2 PGCS
STAT: VOBU 686 at 87MB, 2 PGCS
STAT: VOBU 702 at 92MB, 2 PGCS
STAT: VOBU 718 at 95MB, 2 PGCS
STAT: VOBU 734 at 100MB, 2 PGCS
STAT: VOBU 750 at 102MB, 2 PGCS
STAT: VOBU 766 at 105MB, 2 PGCS
INFO: Video pts = 0.184 .. 391.819
INFO: Audio[8] pts = 0.184 .. 392.152
STAT: VOBU 777 at 107MB, 2 PGCS
INFO: Generating VTS with the following video attributes:
INFO: MPEG version: mpeg1
INFO: TV standard: ntsc
INFO: Resolution: 352x240
STAT: fixed 1 VOBUS
STAT: fixing VOBU at 1MB (17/777, 2%)
STAT: fixing VOBU at 3MB (49/777, 6%)
STAT: fixing VOBU at 5MB (81/777, 10%)
STAT: fixing VOBU at 9MB (129/777, 16%)
STAT: fixing VOBU at 13MB (161/777, 20%)
STAT: fixing VOBU at 21MB (209/777, 26%)
STAT: fixing VOBU at 24MB (241/777, 30%)
STAT: fixing VOBU at 28MB (273/777, 35%)
STAT: fixing VOBU at 36MB (321/777, 41%)
STAT: fixing VOBU at 39MB (353/777, 45%)
STAT: fixing VOBU at 46MB (401/777, 51%)
STAT: fixing VOBU at 51MB (433/777, 55%)
STAT: fixing VOBU at 58MB (481/777, 61%)
STAT: fixing VOBU at 64MB (513/777, 65%)
STAT: fixing VOBU at 68MB (545/777, 70%)
STAT: fixing VOBU at 73MB (593/777, 76%)
STAT: fixing VOBU at 77MB (625/777, 80%)
STAT: fixing VOBU at 85MB (673/777, 86%)
STAT: fixing VOBU at 92MB (705/777, 90%)
STAT: fixing VOBU at 103MB (753/777, 96%)
STAT: fixed 777 VOBUS
INFO: dvdauthor creating table of contents
INFO: Scanning C:\Documents and Settings\zaz\dvd\dvd\dvd\/VIDEO_TS/VTS_01_0.IFO
INFO: Creating menu for TOC
STAT: Processing C:\Program Files\DVDStyler\data\empty_pal_mp2.mpg...
INFO: Video pts = 0.184 .. 6.184
STAT: VOBU 10 at 0MB, 1 PGCS
WARN: aspect ratio was not autodetected
INFO: Generating VMGM with the following video attributes:
STAT: fixed 10 VOBUS
Création de l'image ISO
8.99% done, estimate finish Fri Sep 14 14:38:17 2007
17.94% done, estimate finish Fri Sep 14 14:38:22 2007
26.93% done, estimate finish Fri Sep 14 14:38:24 2007
35.89% done, estimate finish Fri Sep 14 14:38:22 2007
44.87% done, estimate finish Fri Sep 14 14:38:23 2007
53.83% done, estimate finish Fri Sep 14 14:38:22 2007
62.81% done, estimate finish Fri Sep 14 14:38:23 2007
71.77% done, estimate finish Fri Sep 14 14:38:22 2007
80.75% done, estimate finish Fri Sep 14 14:38:23 2007
89.71% done, estimate finish Fri Sep 14 14:38:22 2007
98.69% done, estimate finish Fri Sep 14 14:38:23 2007
Total translation table size: 0
Total rockridge attributes bytes: 0
Total directory bytes: 4248
Path table size(bytes): 42
Max brk space used 0
55738 extents written (108 Mb)
Adding ECC data
Erreur d'exécution de la commande:dvdisaster -mRS02 -n dvd -c -i "C:\Documents and Settings\zaz\dvd.iso"
Thank you if you can help!
Results 1 to 1 of 1
Problem with DVDStyler?
By Regor21 in forum Authoring (DVD)Replies: 1Last Post: 22nd Oct 2010, 09:57 -
DVDstyler error
By Anh Mike in forum Authoring (DVD)Replies: 0Last Post: 16th Oct 2008, 17:39 -
Chapters In DVDStyler
By Astrogirl in forum Authoring (DVD)Replies: 1Last Post: 26th Apr 2008, 18:09 -
DVDStyler Problem
By Astrogirl in forum Authoring (DVD)Replies: 4Last Post: 16th Apr 2008, 13:39 -
Problem with DVDstyler
By zinnia48 in forum Authoring (DVD)Replies: 6Last Post: 24th Nov 2007, 08:22
