I have a linksys cable/DSL router and while trying to get Orb to work changed one of the router settings.
I enabled UPNP and now I'm locked out of the router completely.
I will no longer accept my password!
Anybody know how I can get back into my router?
HELP! PLEASE!!!
TIA!
"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
Usually Linksys routers have a reset button. Just press it for 30 seconds and it should reboot setting its defaults.
This may unconfigure your DSL configuration. -
There should be reset procedures on their website.
Google is your Friend -
Yep... mine i usually hold for 60 seconds but then you can use the default password and have to set everything back up.Originally Posted by ofbarea
Also keep in mind that if you have changed the IP address range for DHCP, resetting it will also revert the IP range and therefore the LAN IP address of the router. Default is usually 192.168.1.1 or 192.168.0.1.
Buy My Books
Getting A New Router
By Tom Saurus in forum ComputerReplies: 17Last Post: 11th Nov 2011, 17:42 -
Locked Folder
By dfisher052 in forum ComputerReplies: 3Last Post: 7th Sep 2011, 18:39 -
VHS Locked
By arcmusic in forum Newbie / General discussionsReplies: 4Last Post: 13th Jan 2011, 11:33 -
Can a router/wireless router shut down computer?
By tmh in forum ComputerReplies: 7Last Post: 29th Jan 2008, 13:34 -
locked post
By jonnyD in forum SubtitleReplies: 1Last Post: 2nd Oct 2007, 11:34
