HI,
Ok, I have an mkv file that I eventually want to turn into a vob. First I extracted the mkv, and I got a h264 video file, 2 aac audios, and one srt for the audio2.aac. When I put the video and both audios in the fields to be muxed...and mux them using "mux as avi+audio", I get that insta-finish which means it didn't actually work, and a very small log that basically just says the audio3.aac is an unknown format. I've played this audio3.aac in vlc to test it, and it's the English audio track, works just fine. Do I have to somehow change the aac into something else (and if so how), or is something else wrong here?
thnx
	I think this AVI muxer wants mp3 or ac3 audio,
 as indicated by the corresponding item on the Tools page.
	Hmmm, I noticed it also makes no mention of being able to mux an h264 file.
 In any case, I decided to just go back to the original mkv (before extracting) and converting that to an avi, it's processing that. If I wanted to turn this into a vob, would I go with the MPEG2-FFmpeg?
 EDIT
 Well, the processing of the mkv failed at 12%, had a ridiculous amount of decoding errors.
 I don't quite understand this whole converting process, I just wanted to turn an mkv into a vob, but it seems easier said than done.
	ok, I installed perian. He said to "decode with quicktime", but no such setting exists on my ffmpeg. He didn't really give any explanation on how he used perian to change the mkv into an avi, and the perian website only says it's for quicktime components so you can watch more movie types in quicktime.
	I guess I use ffmpegx too often, so it seems easy to me. I will put some more details into the original thread.
  MeGUI, problem to encode audio from all AAC format(tape fast-forward sound)By squall0833 in forum AudioReplies: 9Last Post: 13th Jun 2010, 15:54
  MKVtoolnix muxing with h264 and aacBy lovepopp in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2009, 03:23
  I want to conver a file to FLV format. with audio aac and video as mpeg4/h2By krishsamy in forum Video ConversionReplies: 1Last Post: 11th Nov 2009, 03:45
  h.264/AAC audio to AVI/MP3 muxing helpBy Ryutso in forum Video ConversionReplies: 14Last Post: 8th Mar 2009, 13:13
  Covert audio to aac formatBy aruwin in forum AudioReplies: 5Last Post: 25th Aug 2007, 23:34
 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
