I would like to make some backup of some home video into smaller size. How do I accomplish this?
You post your question in DVD authoring and that's probably your final goal but you have to first convert your AVI's to a suitable DVD format.Originally Posted by Newbie_here
Your sources are interlaced (unless you use a progressive scan camera), probably 30 fps and that makes it a bit more complicated. There are different ways to handle interlaced sources and I advice to read posts at the "conversion" forums about this subject. -
You would need to give us more information to start with. What kind of AVI do you have? From a camcorder or a video from a still camera. What format? DV-AVI?
If DV, you might try VirtualDub, the Panasonic DV Codec to open the video, and the Xvid codec to encode. VD has many guides available on it's 'Tool page'. -
Thanks for the replies so far. Yes, I will be using the format DV Avi or dvd mpeg 2 so I would like to be able to convert them to Xvid and/or Divx.
How to add permanent subtitles with AutoGK and convert to AVI DivX or XviD
By Baldrick in forum SubtitleReplies: 263Last Post: 17th Jun 2018, 16:18 -
Convert WMV to AVI / DivX / Xvid
By p_uriel in forum Video ConversionReplies: 5Last Post: 14th Feb 2010, 22:40 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 20:22 -
Can you convert an AVI encoded with Xvid to one with a Divx codec?
By Timfoxx in forum Video ConversionReplies: 3Last Post: 6th Aug 2007, 23:53 -
I need to convert dvd into avi!not xvid or divx!
By picky2112 in forum DVD RippingReplies: 5Last Post: 6th Jul 2007, 03:22
