hello guys i am new here and i need help.
i use adobe premiere pro latest addition and lots of plug-ins.
i have a dvd player and i don't want to use ulead etc.. softwares
i want to record as a real time from adobe premiere to my dvd. And i did it this way;
now i have image but no SOUND !!!!![]()
Do i need matrix card?![]()
please help
Welcome ralphy
Well , if your system specs are correct ... real time is pushing it when cpu is below 2ghz ... record and burn at same time is a resource intensive process , and most would not even attempt it ... one glitch , and you start from scratch .
Nothing wrong with ulead ... if your happy to use adobe products ... or as I call it "adobe bloatware" , then stick with what you prefer .
As for no sound ... if this is on the final dvd , stick it in pc , run ifoedit , and load the ifo with the matching id of the main title vob ... click the ifo in upper window , and internal info appears in lower window ... check what audio is included .
Mp2 is a no go ... and I think dts shouldn't be included unless another audio stream type is included ... there was some info in the forum on audio problems a while back ... https://forum.videohelp.com/topic336724.html?highlight=dts
Ac3_filters might need to be installed in order for pc to play the audio back so you can hear it .
Normally one would output project to pc folder , play it back , if ok , burn it ... the other way round could be a waste media .
Check your intended dvd player ... the one for playback ... its manual on supported audio formats .
VLC Player: no image, only sound
By gracie283 in forum Software PlayingReplies: 23Last Post: 15th Mar 2017, 12:50 -
Windows7 image backup - restoring the image question
By ranchhand in forum ComputerReplies: 18Last Post: 15th Apr 2012, 08:13 -
PowerDVD 10 - Blu-ray sound OK, menu navigation OK but no image
By rilopes in forum Software PlayingReplies: 4Last Post: 10th Aug 2010, 11:16 -
Printed page image don't equal PC monitor's image?
By bryankendall in forum Newbie / General discussionsReplies: 9Last Post: 11th Nov 2008, 14:45 -
Vegas - add image to video (DVD(mpg)) and moving image around
By psxiso in forum EditingReplies: 4Last Post: 11th Jul 2007, 05:29
