When I open a DVD recorded and finalized by my DVD recorder using IFOEdit, I see there are multiple cells per chapter (10 for each 5 minute chapter). When IFOEdit or dvdauthor is used to author a DVD. they create 1 cell per chapter. Out of curiosity as to why the two are different, I looked in the "Cell" entry in the VideoHelp glossary and found the following:
A 'Cell' is a small segment of a chapter (or part). It is the smallest resolution at which DVD navigation commands can act (e.g. 'Jump to Cell 3 of Part 4 of Title 2'). Typically one chapter contains one Cell but on complex DVDs it may be useful to have multiple Cells per chapter.
I spent an hour searching this site for answers to the following questions with no luck, so now I will ask the experts:
1. How are multiple cells per chapter generally used?
2. Is there a free authoring tool for Windows XP that allows one to do this?
Thanks in advance for your help.
Cells are usualy scene changes so the movie can be cut any way you want, also they can be used in Parental level, so not all are played at certain parental restrictions.
They also help to locate layer brake in DVD DL.
Chapter does not need to have one cell, you can see on commercial DVD that chapters have usualy more than one cell.
I do not know any free software, but DVD ReMake can split cells and is not that expensive.
Authoring Blu-ray with chapter points
By ikarishinji41 in forum Authoring (Blu-ray)Replies: 2Last Post: 28th Jan 2012, 06:44 -
Recommended dvd authoring software with manually chapter function...
By Conrad007 in forum Authoring (DVD)Replies: 14Last Post: 27th Feb 2011, 13:54 -
Random DVD Chapter Playback & Other Authoring Questions
By houstono in forum Authoring (DVD)Replies: 18Last Post: 18th Jul 2009, 09:43 -
dvd to cell phone
By molinman in forum Video ConversionReplies: 2Last Post: 4th Jan 2009, 12:25 -
Dvd - cell injection method
By Bjs in forum User guidesReplies: 4Last Post: 8th Jun 2007, 22:58
