Hello guys,
I currently have a project that requires me to capture a client's DVD (vob) on my local hard drive (AVI). I then have to import that to Premiere so I can edit it, and then export.
My question is, what is the best and fastest program I can use (I have 20DVDs to capture) so I can do this project? Currently I've installed Auto Gordian Knot and running the conversion to AVI as I type, but I've checked the settings and I only have two options (xVID, and DIVX). I remember importing a DIVX before in Premiere, that didn't work.. I also checked the program called "FairUse Wizard" but like Auto Gordian Knot, it gives me high-quality xvid or divx.
So, I need a suggestion for a program that converts DVD to AVI fairly fast, but the exported AVI must be editable in Adobe Premiere Pro 1.5.
Thank you very much guys in advance.
niM
DVD is MPeg2. Premiere will edit MPeg2.
You don't want to convert to MPeg4 (divx or xvid).
Depending on your version of Premiere, you may need to demux the VOB to MPeg2 video and audio.
Next decide on a project format for Premiere. You can use DV or uncompressed AVI. Then open your project and import your MPeg files.
You will need to render the timeline to get a smooth preview. -
edDV,
Thank you so much for the reply, I really appreciate it.
I guess my next question is... What is the program to demux the VOB to MPEG2? Is the video file format going to be .M2V after demuxing? I did try to import the VOB to Premiere Pro 1.5, that didn't work as expected.
Thank you again.
niM -
Originally Posted by nimdivino
In general you can go to the "Tools" link on the left menu <<<<<<<<<<<
and select whatever conversion you're attempting from the drop-down box, and get a list of all tools capable of that particular conversion.
Cheers,
Jim -
you know... I'm not surprised one bit.. I actually found it right after I made my response. haha. And funny, I actually already have it on my computer installed..
Anyway, I'm converting now.. I hope this goes smoothly.
Thank you guys again for the help..
niM
mkv - avi/adobe premiere compatible
By Encrtia in forum Video ConversionReplies: 12Last Post: 5th Dec 2010, 11:12 -
Trouble Importing avi file into Adobe Premiere
By Top Gun in forum Newbie / General discussionsReplies: 8Last Post: 18th Jul 2010, 13:21 -
Replacing mpeg to avi in Adobe Premiere
By Cyroq in forum EditingReplies: 7Last Post: 7th Oct 2009, 12:57 -
Compressing an uncompressed AVI (adobe premiere pro)
By marcos316 in forum Newbie / General discussionsReplies: 1Last Post: 19th Jan 2008, 22:07 -
Cant import AVI files into Adobe Premiere Pro 1.5 (again)
By Undead Sega in forum EditingReplies: 1Last Post: 13th Oct 2007, 20:35
