Why are most of the DVD players unable to play the MiniDVD?
What minidvd are you talking about? Those small 8cm dvds? or dvd-video on cdr/w?
The non-comprehensive (and somewhat-outdated) "well-known" DVDFAQ
( http://www.dvddemystified.com/dvdfaq.html#5.7 )
says:
The typical non~cDVD-capable standalone players are the ones made in/for the U.S.A..Unfortunately, you can put DVD-Video files on CD-R or CD-RW media, or even on pressed CD-ROM media, but almost no set-top player can play the disc. There are a number of reasons DVD-Video players can't play DVD-Video content from CD media:
1) checking for CD media is a fallback case after DVD focus fails, at which point the players are no longer looking for DVD-Video content
2) it's simpler and cheaper for players to spin CDs at 1x speed rather than the 9x speed required for DVD-Video content
3) many players can't read CD-R discs
DVD devices made "for the rest of the world" usually are less "narrow-minded".
Also consider that a blank DVD is as cheap or cheaper than a CDR. A blank DVD can be bought for $0.30 and holds the same as 6+ CDR's. One blank CDR is $0.20? It simply doesn't make economic sense anymore. DVD burners are 30-40 dollars,CDR burners 25-30.
Media Players Handle mini-DV (dvsd) Format?
By webpa in forum Media Center PC / MediaCentersReplies: 9Last Post: 3rd Apr 2011, 00:03 -
Best format to copy VHS and DVC's (mini) to make sure they'll last?
By shaytala in forum Newbie / General discussionsReplies: 3Last Post: 12th Sep 2010, 13:53 -
converting DVD mini disk files to compatible APPLE format- video is missing
By MovieMom in forum Video ConversionReplies: 2Last Post: 5th Sep 2010, 13:33 -
What settings/format to convert Mini DV camcorder tapes with Vegas
By piperpilot12w in forum Newbie / General discussionsReplies: 0Last Post: 26th Aug 2010, 12:37 -
Hardware choices: standalone mini-DV deck, or cheap mini-dv camera?
By SgtRauksauff in forum Newbie / General discussionsReplies: 3Last Post: 14th Oct 2008, 02:18
