My Sony DAVS500 is 7 years old and has already been multiregion chipped.
It will not recognise either DVD-9 discs (from Shanghai) or DVDs burnt by me on my PC or MACBOOK. (DVD- or +). In both cases the player displays NO-DISC or sometimes DISC DIRTY.
Is it simply that my player is a bit too old or is there something simple that I can do to resolve the problem.
Many thanks
Likely the player is just failing. With age, the lazer often becomes less powerful. The first types of discs to exhibit issues are recordable discs. If it is in a smokey/dusty environment, you could try cleaning the lazer, but don't expect too much. You may get several more years of use with commercial discs.
Google is your Friend
VirtualDub to sony vegas problems HELP
By iTzRingoBrown in forum Capturing and VCRReplies: 3Last Post: 2nd Jul 2010, 11:08 -
Problems with Sony DVD Architect
By Boomer8404 in forum Authoring (DVD)Replies: 1Last Post: 30th Dec 2009, 03:19 -
Problems using Sony Vegas
By prl in forum EditingReplies: 5Last Post: 24th Jul 2008, 20:49 -
Problems with Sony DVD Recorders?
By BPH2002 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 2nd Feb 2008, 11:44 -
sony vegas 6.0 + Dvd problems
By mp4guy in forum EditingReplies: 8Last Post: 16th May 2007, 22:49
