    Sep 2007
    I downloaded a .MKV file and want to convert it onto DVD.
    When i add it as an asset , the preview only plays sound, there is no video....?
    How can i get the video to work?
    Has anyone successfully converted MKV files with SVCD2DVD???
    thanks in advance...
    ps. I am using SVCD2DVD 2.5
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Should convert no problems.... To VIEW it in the preview - you need to be able to view it in WMP. Typlically you need a splitter and a h264 codec to do that. ffdshow will resolve this (one of many).... If you are not bothered about a preview - just convert as normal.
    Sep 2007
    thanks for that chrissyboy, will give it a try!
