hello everybody, does anyone has ever made to get msu subtitle remover wroked properly? I am trying for a few hours now, to blur the hardsubs on a movie, but the result is to get mane pixeld of the video blured etc
I hop that someone will reply soon!
ps: don't post the link to writer's site's guide, becasue it's not a guide, it jsut explains the definitions :P
Yes and no , it takes time and much adjustment ... if their large , it will cause sever pixelization to appear because it needs to be recompressed .
I had better results by converting test samples to dv avi and applying the filter , then recompress later . -
u confused me a little bit :P
what dv avi is?:S
here is a screenshot of the movie with the hardsubs:
and here is a german version of it, which has the subs blurred!
You could use a DV codec like the Panasonic DV Codec and open the video in VirtualDub or VD Mod, then re-encode to DV format. You may have to resize to DV framesize, 720 x 576 pixels PAL or 720 x 480 NTSC, depending on which system you are using.
and after re-encoding, the filter will have better results? :P
why do i have to re-encode it anyway?:P -
The problem is when you use such filters for video , it gets re-encoded again , and the quality can go south if you don't do it right first time ... dv avi is a safer bet to handle when it comes to such processing .
As for better results ... remember its how you apply the filter ... you may find you need to make a few adjustments before you get something suitable ... in any case , you'll get close , but thats all .
I don't mind subs ... its those channel icons that tick me off ... I already know what channel I'm watching .
VirtualDub crashes when using MSU Subtitle Remover :(
By ralf07 in forum SubtitleReplies: 1Last Post: 17th Mar 2012, 03:16 -
How to get an "l"not an "I" when ripping the dvd subtitle to text format
By cairuitao123 in forum SubtitleReplies: 12Last Post: 24th Mar 2010, 21:50 -
Help needed with MSU Subtitle Remover in VDub
By Lippy Lipstick in forum SubtitleReplies: 11Last Post: 5th Mar 2010, 09:03 -
MSU subtitle remover, the great lie!
By driva in forum Newbie / General discussionsReplies: 5Last Post: 27th Dec 2008, 20:37 -
VirtualDub MSU Subtitle Remover directions help
By LangleyM in forum SubtitleReplies: 4Last Post: 6th Feb 2008, 08:56
