Hey ive got a .img file and i cant burn it to dvd with ImgBurn as ive only got the cheapest dvd-rs money can buy.
So it says "Device not ready (medium not present)"
So i ive decided to turn it into a VOB file, which i can then convert with videora to any format like iPod or PSP, large avi to play on my pc screen.
I cant find anything to convert .img files to VOB or avi or mpeg4 or anything at all to be honest.
I can only find burning from .img to dvd (DVD decryt/imgburn) but like i said b4 i cant really do that because ofmy lack of a verbatim dvd-r.
Can anyone recommend a good program for converting .img to multiple formats or any of the ones i mentioned
Thanks in advance...
(ps im looking for freeware)
Results 1 to 9 of 9
As an IMG isn't a media file, but rather a "snapshot" of a CD or DVD disk, that can contain any kind of files, it can't be converted to a media file.
But mount it with Daemon Tools, and take a look what's in the img, and perhaps it can be converted to something playable for you.
/Mats -
Daemon tools doesnt recognize, it, eveyone telles me to rename to .ISO
so i renamed it to XXXX.ISO but the file type remains .IMG? -
If so, you probably have the option "Hide extension for known file types" enabled in Windows Explorer. A very stupid default setting to be changed immediately. Open any folder, take a look under Tools, Folder options, Show tab (at least I think it's "Show" in UK Windows) and uncheck that option.but the file type remains .IMG?
/Mats -
There no show tab and i checked thru for settings realting to "show" and the only unselected show was "show hidden folders" i selected "display full path in title bar" but that changed nothing aswell
It still says XXX.ISO but stays as IMG under file type?
Any ideas? -
Img = clonecd (under no circumstances rename it to iso)
Try cdmage : http://cdmage.orcon.net.nz/frames.html -
cool thanks ive managed to use iso buster to extract the video ts/VOB's that im used to dealing with, do you reckon image burn would be less picky with me burning the VOB's to a cheap disc as opposed to burning the .img to disc which didnt recognize the disc.
If ImgBurn doesn't recognize you have a disk in the drive (Device not ready (medium not present)), it won't matter much what you try to burn...
/Mats -
It could be bum media - you don't mention what it is nor an MID code..Not that you'd probably be able to get it since your drive doesn't seem to recognize anything in it. It could be a bad IDE port on your motherboard, bad cable, the drive itself could be shot or on it's way out...And so on - could be a combo of any of the above as well.
ps It might help if you filled in your PC specs more thoroughly too.
[edit] On a personal note, I had an NEC (3550A) drive that had this issue, among others..Not recognizing media, not being able to burn to most media, and when it did not being able to read the disc directly after, not at full rated speed (16x, stuck @ 8x), and crappy burn 'quality' as well.. Not able to read either pressed or most burned media (known good)..And so on. When I finally had enough and chucked it in favor of my current Pioneer DVR-112, all my problems went away.
Looking @ scan.co.uk, you can grab any number of good drives for $16-18 GBP (inc. VAT), ~$30-35 here in the 'States'.
Convert MPEG4 Video to VOB?
By jfreytag in forum Authoring (DVD)Replies: 6Last Post: 30th Oct 2010, 22:55 -
Encoding .DV problems with ffmpeg (e.g. MPEG4 -> DV or VOB -> DV)
By AlphaMonk in forum ffmpegX general discussionReplies: 1Last Post: 23rd Feb 2010, 05:24 -
DVD chaptered VOB's to MPEG4?
By procooper in forum DVD RippingReplies: 1Last Post: 24th Nov 2007, 18:08 -
? converting vob to mpeg4 or divx for dummies
By Newbie_here in forum DVD RippingReplies: 2Last Post: 27th Jul 2007, 15:25 -
Question on conversion from VOB files to MPEG4
By donkeyking in forum Video ConversionReplies: 8Last Post: 17th Jul 2007, 17:56
